Re: Anybody run a Legend Gear 5spd trans?
[Re: NV69B7RR]
#2046888
04/05/16 05:23 AM
04/05/16 05:23 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I have the LGT-700, it is a Keisler kit. Installed in my '69 Coronet. Kit was a joke, had the rear of the trans hanging low to clear the T-Bar crossmember. This made the headers hit the suspension. I measured the output shaft to top of trans tunnel before removing the original. To put the LGT in, I had to cut the T-Bar crossmember for clearance to raise the trans output shaft. Also, the speedometer gear comes out in-line with the T-Bar cross member, so the cable takes a sharp bend. So far that has not cause a problem.
Other than the fitment issue, the trans works great. Silver Sport Transmission sent me an E-mail that they have a "Perfect fit" 6-Speed for the B-Body. They mention a solution for the T-Bar crossmember, but not what that entails?
