Page 3 of 4 1 2 3 4
Re: Fast cars with a third pedal... [Re: 68LAR] #2194863
11/11/16 05:40 PM
11/11/16 05:40 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
whistling
69 GTX 68 Road Runner
Re: Fast cars with a third pedal... [Re: JERICOGTX] #2194940
11/11/16 09:16 PM
11/11/16 09:16 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
The fellow on the left was fast. Almost like an explosion when he passed by. Skeered me! But then again, fast is relative drive
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Fast cars with a third pedal... [Re: OhioMopar] #2195063
11/12/16 05:21 AM
11/12/16 05:21 AM
sweden
sshemi Offline
sshemi  Offline
sweden
Damn thats a great race!!!
Re: Fast cars with a third pedal... [Re: OhioMopar] #2195095
11/12/16 11:02 AM
11/12/16 11:02 AM
Mo.
racerx Offline
racerx  Offline
Mo.
He is fast smoke what kind of car was this?
Re: Fast cars with a third pedal... [Re: racerx] #2195122
11/12/16 12:23 PM
11/12/16 12:23 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
it was a fairly serious mustang. I think it had a gforce trans.
a couple of fast mopars - mid high 8s both small blocks
Re: Fast cars with a third pedal... [Re: oldiron] #3090962
11/01/22 03:13 PM
11/01/22 03:13 PM
Minnesota
skep419 Offline
skep419  Offline
Minnesota
Re: Fast cars with a third pedal... [Re: skep419] #3091050
11/02/22 12:43 AM
11/02/22 12:43 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Are we supposed to respond to this Lazarus thread?
Ok, I'll do it.
31 Plymouth coupe, street/strip, completed 2 Drag Weeks, mostly stock except for a stroked early Hemi, 8 Holley 94 carbs, t56 magnum, McLeod RTX clutch, Clutch Tamer, quicktime bell, 4.57 Moser 9" , 4 link, coil overs, 8.50 cage, 2750# at the starting line. Haven't broke anything, gone 10.teens at 137. Still needs a lot of sorting, I expect 9's from it.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Fast cars with a third pedal... [Re: Hemi_Joel] #3091053
11/02/22 01:25 AM
11/02/22 01:25 AM
New York, USA
Chargerfan68 Offline
New York, USA
I guess i fit into this category:
68 charger R/T
505 rb 10.6:1
1050 dom
Jerico dr4
4.30 rear gear
Leaf spring/caltrac
Pretty porky….3900
Runs pretty consistent: 10.75 @ 127
Re: Fast cars with a third pedal... [Re: Chargerfan68] #3091069
11/02/22 07:12 AM
11/02/22 07:12 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
68 Road Runner.
Old 499ci combo with a Jerico DR4, ran 9.72 @ 138mph.
New combo, with 563ci made 140 more HP, and I switched to a Clutchless Liberty 4 speed. Should run bottom 9's, high 8's on a good day.
Re: Fast cars with a third pedal... [Re: JERICOGTX] #3091104
11/02/22 10:27 AM
11/02/22 10:27 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I don't race much anymore but my best pass was 10.91 at 124 in my Savoy.
493 with Indy EZ heads, mild flat tappet cam, 10.9 comp, Richmond 5-speed with faceplate by Liberty's, Long V-gate, 3.54 D-60, Performer RPM with a QF 1050 4150 carb. Older Hays MK XII adjustable plate and Ram bronze disc.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Fast cars with a third pedal... [Re: 68LAR] #3091182
11/02/22 03:07 PM
11/02/22 03:07 PM
UK
rb446 Offline
rb446  Offline
UK
How about Peter Willie and his '71 Cuda>
https://www.youtube.com/watch?v=QlfRBLYcKi8
This is the motor I believe>
https://www.youtube.com/watch?v=p7mjI9yj128
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: Fast cars with a third pedal... [Re: rb446] #3091230
11/02/22 06:42 PM
11/02/22 06:42 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Mine isn’t as fast as what you’re looking for, but I’ll bite. Mine went 12.57 @ 113 last weekend, with a soft 1.79 60 ft and sloooow shifts. It took 9 passes, but thats the first complete pass the car has run. From here I can try to launch it harder and shift it faster.
Do you guys find shifting slow affects trap speed or et more?
Combo is stock stroke 440, Racer Brown ST-21 (254 @ .050, 520 lift), 107 LSA, RPM intake with an 850 DP, Stealth heads, 18 spline with a Ram Powergrip HD, and 4.10 8 3/4 (reason for babying the launch and shifts).
The last 3 passes the clutch seemed to slip in first, I pedaled it some and it locked up and held for the rest of the run. But I was actually thinking about throwing a 727 in it to see what it runs with it whistling
Re: Fast cars with a third pedal... [Re: GTX MATT] #3091308
11/03/22 04:36 AM
11/03/22 04:36 AM
Netherlands
72Challenger Offline
Netherlands
In the past (racing is 99% dead over here so meanwhile sold the car) I have gone 8.9's with my Challenger.
Guestimate at around 2900lbs
528 pumpgas, flat tapped cammed, single dominator, Hemi
Gforce clutchless 4speed and adj. clutch I believe from Hyatt.
Dana60 with 456 gears and 33" slicks.
Had some topend troubles with the engine so was potential a 8.7 I guess.
Re: Fast cars with a third pedal... [Re: 72Challenger] #3091462
11/03/22 05:58 PM
11/03/22 05:58 PM
East Brunswick New Jersey
N
NoFrills Offline
NoFrills  Offline
N
My junk is heavily inspired by the sweed 4 speed r5p7 11.1 358 g force gf5r 5 speed Dana leaf spring cal tracs goes 9.50s 142 in the heat recently figued out I'm driving through the clutch over 8000 rpm I leave at 6000 shift at 9 go through the traps around 9500
Re: Fast cars with a third pedal... [Re: NoFrills] #3091600
11/04/22 12:08 PM
11/04/22 12:08 PM
Canada
cuda499 Offline
cuda499  Offline
Canada
Have a 70 cuda with an alum 572 hemi and a G5R-Gforce 5 speed. When i took out the wedge and put the hemi in, the car hasn't been on the clocks much. They did turn them on at a no prep event in final round and it went 6.0@115 on motor in 1/8. Tranmission isnt clutchless, and it has 2 kits on it. I use a twin disc slipper and it runs on holley efi with individual coil packs. The car is on a 29X10.5W or a 28X10.5 and currently has a 4.10 gear. Currently putting together new motor for it and doing some upgrades to rear suspension.
Re: Fast cars with a third pedal... [Re: cuda499] #3092576
11/08/22 02:35 PM
11/08/22 02:35 PM
Minnesota
skep419 Offline
skep419  Offline
Minnesota
Thanks for sharing, looking for inspiration. I'm putting together a 69 Dart stock bottom end/head 5.9 magnum, cam/springs, air gap intake, Centerforce clutch 440 source flywheel, 2.66 23 spline A833, 8 3/4 3.23 gears (I have a complete 3.91 742 center if needed) Hoping it will run in the 7's 1/8.
Re: Fast cars with a third pedal... [Re: JERICOGTX] #3093532
11/11/22 07:24 PM
11/11/22 07:24 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I have one I still need to sort out. ‘74 cuda, 3650 race weight. 511/trickflow 270, tkx 5-speed. I managed to make a couple easy passes this summer but didn’t have a rollcage yet so I launched and shifted easy.
Went 11.26@130.5.
https://youtube.com/shorts/sYdGhhFns7g?feature=share
Re: Fast cars with a third pedal... [Re: viperblue72] #3093582
11/11/22 10:53 PM
11/11/22 10:53 PM
Rittman Ohio
Rittman Ohio
Went 11.26@130.5.
How do you like the TKX gearbox? Does the shifter go smooth at high RPM's ? I haven't read many reviews about how they react on the strip with some HP in front of them.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Fast cars with a third pedal... [Re: fourgearsavoy] #3093703
11/12/22 01:13 PM
11/12/22 01:13 PM
V
viperblue72 Offline
viperblue72  Offline
V
The shifter I got from silversport is a bit of a long throw. First and second gear are a bit lower than ideal. 5th is really tall.
I shift at 67-6800 It still seems a bit catchy at high rpm but it could be my clutch needs more engagement. I’m not in love with the hydraulic setup because I have to push the pedal clear to the floor before it disengages. Although that could be adjustment issues. I am hoping I can shim it. I think it will be a nice setup once I have it worked out. But I do feel it’s going to be a better street trans than strip. And with a smaller cubic inch setup I think the gearing would be better suited. My 511 really starts to pull hard once I hit 3rd.
Fwiw I’m running a 29” slick and 4.10 rear. I still think mid 10s aren’t going to be a problem once I start making real passes.
Re: Fast cars with a third pedal... [Re: viperblue72] #3093741
11/12/22 03:54 PM
11/12/22 03:54 PM
Rittman Ohio
Rittman Ohio
Thanks I have a few of my 833 customers asking me about converting their cars over to some type of OD box. The online claims as to the strength of this box are as usual seem highly inflated. I have built a few T56 transmissions and the design prohibits high speed power shifts even when the gears are face-plated.
I may just sell a few of my transmissions and buy one of these boxes as my car is more street than strip right now. I only hope that is will hold up to the torque and weight of my car with sticky tires. I will probably install the adjustable clutch or try one of those Clutch Tamer deals to keep the teeth on the gears.
Gus beer
64 Plymouth Savoy
Dana 60
Page 3 of 4 1 2 3 4
