Page 2 of 5 1 2 3 4 5
Re: Billet valve covers [Re: AndyF] #2064219
04/29/16 08:18 PM
04/29/16 08:18 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Small Block Please
Re: Billet valve covers [Re: Scamp408] #2064232
04/29/16 08:35 PM
04/29/16 08:35 PM
AndyF Offline OP
AndyF  Offline OP
Originally Posted By Scamp408
Small Block Please
I'll pass on that idea. SB Mopar parts don't sell very well for me so I don't intend to invest any more money into that segment.
Re: Billet valve covers [Re: AndyF] #2064236
04/29/16 08:40 PM
04/29/16 08:40 PM
Here
jcc Offline
jcc  Offline
Here
What do they weigh?
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
Re: Billet valve covers [Re: jcc] #2064248
04/29/16 09:02 PM
04/29/16 09:02 PM
dogdays Offline
dogdays  Offline
So these are true billet, right? Meaning they started out as a big block of aluminum. Something like 90% of the aluminum was turned into chips. Talk about machine time!
One can get a pretty nice welded valve cover for $250, but the only thing billet about that would be the valve cover rail, right?
So are there advantages that I am not imagining? Is the reason for billet mainly looks? Or is there something else?
R.
Re: Billet valve covers [Re: dogdays] #2064254
04/29/16 09:11 PM
04/29/16 09:11 PM
AndyF Offline OP
AndyF  Offline OP
Yes, these start out as 35 lb pieces of bar stock and then they mill away 30 lbs and you end up with a 5 lb cover.
The advantage for me is in having a cover that fits correctly and seals up tight so I can run a lot of vacuum. I can also put the material where I want it for threaded fittings and things like that. I've tried most of the valve covers on the market and haven't found anything that really works. A high end custom sheet metal cover could be made to work but the cost is going to be roughly the same. Some of the sheet metal covers that I've looked at are junk although they had a premium price tag.
Re: Billet valve covers [Re: dogdays] #2064267
04/29/16 09:28 PM
04/29/16 09:28 PM
AndyF Offline OP
AndyF  Offline OP
Moroso has some Chevy valve covers which are billet. The BBC covers are more than $700 and I think the SBC covers are in the $650 range depending on which version.
http://www.summitracing.com/parts/mor-68469/overview/
I'll attach a picture that shows what the inside looks like. You can see the tooling marks on the inside. They use different tools on the outside so you don't see the marks.
Re: Billet valve covers [Re: AndyF] #2064341
04/29/16 10:46 PM
04/29/16 10:46 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Wow... that's gotta make a shipload worth of chits when the machines are finally done.
Re: Billet valve covers [Re: AndyF] #2064386
04/29/16 11:56 PM
04/29/16 11:56 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
If you're going to all that trouble, you should incorporate channels for a spray system. I've been thinking about machining the tops off a set of cast covers and making a set of bolt-on plates that have oil passages machined in.
Re: Billet valve covers [Re: AndyF] #2064594
04/30/16 11:31 AM
04/30/16 11:31 AM
Scatchamatoon
Saskabusa Offline
Saskabusa  Offline
Scatchamatoon
What program do you use to design them?
1974 Roadrunner
1967 Charger
Re: Billet valve covers [Re: Saskabusa] #2064619
04/30/16 12:13 PM
04/30/16 12:13 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I'm going to do some small block covers, I'd look at Predator units if Andy isn't interested in doing them. I thought about Hemi ones, but the Noonan ones are really good
Alan Jones
Re: Billet valve covers [Re: AndyF] #2064705
04/30/16 02:17 PM
04/30/16 02:17 PM
AndyF Offline OP
AndyF  Offline OP
I've seen some of the Noonan stuff. I don't know what the prices are on it but the ones I've seen are very pretty.
I think that Ultra Pro stuff that I posted earlier is about the best value available but maybe someone else has experience with another supplier. Moroso has gotten into the billet valve cover business lately with some cool stuff. Their 68050 SBC cover is pretty cool. Super lightweight and the cost isn't too bad at $600 from Summit. That is a good price for a part with so much 3D scanning on it.
Re: Billet valve covers [Re: AndyF] #2065499
05/01/16 09:43 PM
05/01/16 09:43 PM
AndyF Offline OP
AndyF  Offline OP
They even make one of my old core motors look good.
Re: Billet valve covers [Re: DARTH V8Я] #2067058
05/04/16 11:33 AM
05/04/16 11:33 AM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Originally Posted By DARTH V8R
First off, very nice valve covers! But I have to ask cause my knowledge is lacking in this area, what's the difference between your $650 units and other very similar billet ones going for $250? Is it because its the initial run and will get cheaper the more you make? The 1/2" rail? Thanks.
There aren't any "very similar" billet covers available for $250. If there were I would've bought them rather than have these built.
Thanks thumbs
http://www.amazon.com/1958-88-Mopar-383-426-440-Fabricated-Aluminum/dp/B003AKLGTG
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Billet valve covers [Re: DARTH V8Я] #2067062
05/04/16 11:39 AM
05/04/16 11:39 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Thanks thumbs
I like the fabricated covers in the link, nice but not in the same class as billet.
Re: Billet valve covers [Re: DARTH V8Я] #2067238
05/04/16 04:12 PM
05/04/16 04:12 PM
AndyF Offline OP
AndyF  Offline OP
440Source has fabricated valve covers for $170. Fabricated valve covers are made from sheet metal that is welded together. A billet cover starts as a big chunk of aluminum and then the valve cover is carved out of it. Totally different process. Some high end fabricated covers are made from a mixture of billet and sheet metal. I've seen SBC covers which use billet ends and a sheet metal middle. That is a nice way to get the complex shapes in billet but the flat shapes from sheet material.
Re: Billet valve covers [Re: AndyF] #2067275
05/04/16 05:20 PM
05/04/16 05:20 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Andy keep up the great work. I have a couple of your engine plates (and will be buying two more) and I bought a couple water manifolds for the B1 I am building for my small tire car. Very nice products at a fair price. Thanks.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.38@138.67
Re: Billet valve covers [Re: DARTH V8Я] #2067390
05/04/16 08:20 PM
05/04/16 08:20 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Thanks thumbs
That's just a welded sheetmetal cover with a thin gasket rail. Probably comes with a guarantee to warp the rail and leak
Re: Billet valve covers [Re: AndyF] #2067527
05/04/16 11:35 PM
05/04/16 11:35 PM
AndyF Offline OP
AndyF  Offline OP
I think fabricated valve covers all depend on who builds them. Some guys seem to know how to do it while others just build junk. The good ones cost a fair amount. To do it correctly a person probably needs to invest in some proper jigs as well as some sort of tempering oven to relax all of the welding stress. Nice thing about billet parts is that 6061 aluminum tends to be very stable. Pretty rare for the billet stuff to warp over time.
Re: Billet valve covers [Re: AndyF] #2067558
05/05/16 12:37 AM
05/05/16 12:37 AM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Beautiful!
2 kids and a dog
Re: Billet valve covers [Re: AndyF] #2067604
05/05/16 03:30 AM
05/05/16 03:30 AM
LA360 Offline
LA360  Offline
Plus you can really get some weight out them, while still keeping a decent thickness flange for sealing. I'm hoping to get my ones down to 0.030-0.040" thick
Alan Jones
