Page 4 of 5 1 2 3 4 5
Re: ProMaxx Performance 440 heads [Re: Stevenisme] #1654654
03/30/15 08:10 PM
03/30/15 08:10 PM
Crabman and Dunnuck, I know each engine could be different, but in general, what is the pushrod clearance like with these heads and 3/8" pushrods and 1.5 rockers? Have you had to grind for clearance or not had to grind for clearance in most cases? Thanks!
I did not hear anything about the clearance. If there is before, there is not afterwards.
Steve I am doing one later this week on a 440 with 3/8ths pushrods and a .575 solid roller with Harland Sharp 1.5 ratio rocker arms I will let you know how it works out
Re: ProMaxx Performance 440 heads [Re: BradH] #1654655
03/31/15 05:54 PM
03/31/15 05:54 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
@Crabman,
David,
Is the set you're talking about the set that Larry Smith ported for Todd (Sasquatch?) Or was that a Small block Procomp set, I can't remember.
Not trying to Threadjack, I know Todd's doing a lot of cool things with the Sidewinders
WIZE
In Car:
Re: ProMaxx Performance 440 heads [Re: Streetwize] #1654656
03/31/15 09:06 PM
03/31/15 09:06 PM
We have been usingthem like popcorn--so far have done everything from swap them on a 440 with 509 hyd--wowzer--out of the box stamped rockers GREAT engine---- to some port work , 440 ,big hyd cam and an EASY 569HP first pull--full ported are showing better and better numbers as Larry zeros in on them--I have a set on a 511 right now that I just cleaned up on my back yard bench--street solid roller --will report as it moves along--not pulling every angle just tossing it together and see what happens--
So far with 1.5 PRW rockers and 3/8ths push rods I had them all clear on a street hyd roller unit--have Harlands on this 511 so we'll see soon as Smith gets the tubes here
Re: ProMaxx Performance 440 heads [Re: young guns 90s] #1799674
04/09/15 06:50 PM
04/09/15 06:50 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
Heads were delivered today.
Pluses
They look really nice... a very nice finished look
Bowls and exhaust ports look perfect
Very little cleanup left to do OOTB
Minuses
Need a little cleanup to match the intake ports
Stamped locks so those will have to go
Doesnt look like any of the holes are helicoiled so hopefully that wont be an issue
I've ran 906's, Edelbrocks and 440 Source Stealth so far and would say the new ProMaxx Heads look very promising at an unbelievable price point.
Once I get the intakes port matched and clearance the pushrod holes a bit for good measure I'll get to my engine builder to see what he thinks.
I see 5.90's in my future smile
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: ProMaxx Performance 440 heads [Re: 69dart] #1799802
04/09/15 09:22 PM
04/09/15 09:22 PM
crabman173
crabman173
3/8ths pushrods cleared with PRW stainless rockers--They will NOT clear with Harland Sharp 1.5's I worked and worked but was afraid of boring through an intake wall or worse so I quit and ordered Smith Bros 5/16ths pushrods for this 511 Smith says good for 700 open I got 460 range so am not worried about that part
They clear ok at the bottom but up near the top it was trouble
The Smith Brothers 5/16ths are my go to for this issue on street engine now--Geeez!
I am getting too old for this I need a career change
Steven in China Listen up!
Re: ProMaxx Performance 440 heads [Re: young guns 90s] #1799838
04/09/15 09:58 PM
04/09/15 09:58 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I have been using the thick 5/16 from Smith Brothers on a few street engines. They work great, and I don't have to mess with clearancing the head.
The only Carbs I care about are under the hood!
Re: ProMaxx Performance 440 heads [Re: young guns 90s] #1799851
04/09/15 10:09 PM
04/09/15 10:09 PM
crabman173
crabman173
I actually sent for the .080 wall as they assured me they were stout enough they also had the .120 wall but -----he said they might make me sleep better but that at my 9 inch length the 080 was rated at near 700 open--I figured they knew and so... They do look like the future as far as I am concerned smile
Re: ProMaxx Performance 440 heads [Re: young guns 90s] #1800285
04/10/15 01:12 PM
04/10/15 01:12 PM
jax. fla.
70Dustmite440 Offline
jax. fla.
crabman173 is over their Private Message Limit.... just saying wink
8sec. street car, been there done that. Quitting when your ahead isn't the same as quitting.
[img]https://scontent-atl.xx.fbcdn.net/hphoto...amp;oe=55DB3E4C[/img]
https://www.facebook.com/eric.norton.1048
R.I.P.UN.
Re: ProMaxx Performance 440 heads [Re: young guns 90s] #1873193
07/18/15 09:28 PM
07/18/15 09:28 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
Okay - so I dropped a valve on my 440 source heads. So the ProMaxx heads will get a back to back comparison.
I did clean up all the ports and have the springs, retainers and locks swapped for titanium roller cam stuff.
So far I've been impressed everything has fit. The 3/8's pushrods did require substantial clearancing to fit the lowdeck with my mopar 1.6 rockers but everything else has been good.
Sounds nasty in the driveway so we'll see how she runs tomorrow. Hopefully it'll run 5.90's since it went 6.teens with untouched 440 source heads.
Honestly as long it lives the rest of the season I'll be HAPPY!!!
68 Dart - 340
66 Belvedere - 400
Re: ProMaxx Performance 440 heads [Re: young guns 90s] #1873354
07/19/15 07:35 AM
07/19/15 07:35 AM
crabman173
crabman173
1.6 ratio is always a PIA on any Mopar head
The Sidewinders are a bit fatter at the top of the intake port--I have had to do more on them than other heads
You will like them!
Re: ProMaxx Performance 440 heads [Re: ] #1873770
07/19/15 07:54 PM
07/19/15 07:54 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
Well the weather was horrendous today. In the 90's with 76 dew point so I'm not sure how good of a back to back it was. The car ran exactly the same as it did the last time out.
I think I'm going to add some timing and maybe fatten up a jet or too as it did seem a bit lean on the big end with. I set the timing at conservative 34.
Most guys were a tenth or so slow and we ran the same so they 'might be better'.
I'm just thrilled its put away in one piece and ready for the Mopar Nats smile
68 Dart - 340
66 Belvedere - 400
Re: ProMaxx Performance 440 heads [Re: 69dart] #1886633
08/06/15 10:04 PM
08/06/15 10:04 PM
any updates on your car with the newheads? Also, who did you buy yours from and where they complete and ready to bolt on? Thanks, Cab
Re: ProMaxx Performance 440 heads [Re: Cab_Burge] #2063660
04/28/16 10:11 PM
04/28/16 10:11 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
Update: The roadster has gone 5.98 @ 114 in the 1/8 and 9.63 @ 134 since replacing the heads.
I have to admin I'm pretty happy getting a 5.98 from a TRW piston 383 with a torker intake and 750 E85 carb. The car is just plain nasty with this combination. I couldnt be happier with these heads.
68 Dart - 340
66 Belvedere - 400
Re: ProMaxx Performance 440 heads [Re: 69dart] #2063674
04/28/16 10:31 PM
04/28/16 10:31 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Congrats man.............
Re: ProMaxx Performance 440 heads [Re: young guns 90s] #2105109
07/06/16 05:59 PM
07/06/16 05:59 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Let's dust this off shall we? I see the Promaxx head at Jegs for a very attractive price point. I search for Sidewinder heads and all I see references to this and other discussion boards.
Where does one procure these Sidewinder heads that you speak of?
Has any ONE bench flowed all of the new heads out there:
ProMaxx
Sidewinder
Eddys
440 source
Also...what head is CPPA/Toth plagiarizing?? Looks like all of the others in pics.
Carry on...
Re: ProMaxx Performance 440 heads [Re: young guns 90s] #2105111
07/06/16 06:01 PM
07/06/16 06:01 PM
an8sec70cuda Offline
Todd Marsh at Marsh Performance http://www.mopartsracing.com/
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'70 'cuda, 575" Hemi, 727, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
'17 Ram 1500 5.7 Hemi
Re: ProMaxx Performance 440 heads [Re: an8sec70cuda] #2105185
07/06/16 07:21 PM
07/06/16 07:21 PM
cudadoug Offline
cudadoug  Offline
BOOM! That's what I was looking for. Thank you, sir!
Re: ProMaxx Performance 440 heads [Re: young guns 90s] #2105260
07/06/16 09:10 PM
07/06/16 09:10 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i've been looking around trying to figure out how close the sidewinders (and i think therefore, the promaxx) are to the edelbrock heads. they seem pretty close. stealths flow a little less than sidewinders. i haven't really figured out if the edelbrocks flow more than the sidewinders but i imagine it won't be a large amount...
gotta give a thanks to dwayne for posting flow numbers (all over the place, and in the tech forums) and also giving me the lowdown on configurations of the sidewinders and stealths.
i'm not buying parts yet but i think some sidewinder type heads will be enough for a hot street motor i want to put in my coronet. save some money on the heads and put that towards rear suspension stuff or a nice converter...
Re: ProMaxx Performance 440 heads [Re: young guns 90s] #2105266
07/06/16 09:19 PM
07/06/16 09:19 PM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
Competition products has the promaxx ones too.
Re: ProMaxx Performance 440 heads [Re: young guns 90s] #2192301
11/08/16 05:32 PM
11/08/16 05:32 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
bumpin this up, Jeg's has the 240cc port Promaxx heads now.
a few different valve spring configurations. 2.19/1.81 valves.
no pics or flow charts for them though, the pic in the listing is the regular promaxx BBM head...
http://www.jegs.com/p/ProMaxx-Performanc...947797/10002/-1
