Winter Storage/Stabil or Not Stabil? #2191360
11/07/16 12:56 PM
11/07/16 12:56 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
I store the car in an airtight bag in a semi heated garage (never below 40 deg.) Full tank of gas, just wondering what everyone else is doing?
Thank you! up
Admiration For Multiple Carburetor Vehicles...
Re: Winter Storage/Stabil or Not Stabil? [Re: Stewpar] #2191389
11/07/16 01:33 PM
11/07/16 01:33 PM
I use it, tho I cant say I have ever had an issue with gas deteriorating but then again my stuff never sits for months on end. On the other, just wondering, is it sealed completely airtight?
Re: Winter Storage/Stabil or Not Stabil? [Re: Stewpar] #2191422
11/07/16 02:01 PM
11/07/16 02:01 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
When i remember to use Stabil, I use it. When i don't - I don't!
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: Winter Storage/Stabil or Not Stabil? [Re: Stewpar] #2191426
11/07/16 02:03 PM
11/07/16 02:03 PM
Massachussetts
RCKTMN Offline
RCKTMN  Offline
Massachussetts
I've used K-100 fuel treatment with great results...Both for fuel system cleaning and long term storage. They make formulas for both gasoline and diesel.
Regards,
Paul
1970 Barracuda Convertible
1970 Newport Convertible
1970 Satellite Convertible
1974 'Cuda shell - '71 conversion
1988 Oldsmobile Cutlass w/455
2003 RAM3500 CTD
2007 Caliber R/T AWD
2007 Magnum SRT-8
2016 Chrysler Town & Country
Re: Winter Storage/Stabil or Not Stabil? [Re: RCKTMN] #2191431
11/07/16 02:06 PM
11/07/16 02:06 PM
Massachussetts
RCKTMN Offline
RCKTMN  Offline
Massachussetts
Forgot to ask...
Which car bag are you using?
How do you like it?
Thanks,
Paul
2003 RAM3500 CTD
2007 Magnum SRT-8
Re: Winter Storage/Stabil or Not Stabil? [Re: RapidRobert] #2191521
11/07/16 03:25 PM
11/07/16 03:25 PM
dogdays Offline
dogdays  Offline
Go ahead and use it. I'd suggest adding two times the suggested quantity and running the engine for several minutes, to get the additive into the fuel lines and injectors/carb(s).
I mean, what does it cost? peanuts.
R.
Re: Winter Storage/Stabil or Not Stabil? [Re: dogdays] #2191590
11/07/16 04:44 PM
11/07/16 04:44 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
http://www.carbag.com/products/carjacket
This is what I have and is darn near air tight.......
Re: Winter Storage/Stabil or Not Stabil? [Re: Stewpar] #2191641
11/07/16 05:59 PM
11/07/16 05:59 PM
South Carolina
carhunter Offline
carhunter  Offline
South Carolina
I use stabil and I have the same carjacket, works great.Just make sure you let the car cool off before zipping it up,and put moisture bags in and under car to suck up any moisture that may be in there.I used it many years now without any problems.
Re: Winter Storage/Stabil or Not Stabil? [Re: dogdays] #2191648
11/07/16 06:09 PM
11/07/16 06:09 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
R.
^^^this, plus your full tank ought to be good.
Re: Winter Storage/Stabil or Not Stabil? [Re: Stewpar] #2191652
11/07/16 06:12 PM
11/07/16 06:12 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I use Sta-Bil a lot. I use more than the suggested amount...4 oz to 5 gallons of fuel. Never had a problem with fuel going bad using it.
Nautilus Racing-
Re: Winter Storage/Stabil or Not Stabil? [Re: Chris2581] #2191660
11/07/16 06:25 PM
11/07/16 06:25 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
After talking to other friends, I am going with this. Does more than Stabil (mainly isopropyl alcohol) as far as protecting the gas and engine surfaces.
https://shop.briggsandstratton.com/us/en...tment-100118web
Re: Winter Storage/Stabil or Not Stabil? [Re: Stewpar] #2192059
11/08/16 10:43 AM
11/08/16 10:43 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
I used to put sta bil in until I had issues with my snowblower (used it there as well). Now I use startron in my 5 gallon jugs at home and seafoam instead of sta bil for storage.
Re: Winter Storage/Stabil or Not Stabil? [Re: Stewpar] #2192076
11/08/16 11:33 AM
11/08/16 11:33 AM
None
71rm23 Offline
71rm23  Offline
None
I use Stabil and a bottle of "Heet".
Re: Winter Storage/Stabil or Not Stabil? [Re: Stewpar] #2192082
11/08/16 11:37 AM
11/08/16 11:37 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I have used sea foam before as a fuel stabilizer. Do any fuel stabilizers really do anything? I can't say for sure. I've stored engines without anything and not had problems, I've stored some with fuel stabilizer and had stuck floats the next year. I think next I want to try the marine sta-bil.
Re: Winter Storage/Stabil or Not Stabil? [Re: MI_Custumz] #2192096
11/08/16 11:56 AM
11/08/16 11:56 AM
the Ardizam engineer that I worked with with my 2 cycle roto tiller from Hell was a proponent of Startran and I've heard good regarding Seafoam. To me the others (& there is a ton of em) are snake oil
