diameter of LA SB exhaust manifold ball? #2191693
11/07/16 07:34 PM
11/07/16 07:34 PM
Central Valley, CA.
Quicksilver440 Offline OP
Central Valley, CA.
I need a socketed downpipe to use on a '77 318 exhaust manifold ball and I'm not sure what size it is. The exhaust is 2".....is the ball/socket typically 2.5" or 3"?
Re: diameter of LA SB exhaust manifold ball? [Re: Quicksilver440] #2191714
11/07/16 07:58 PM
11/07/16 07:58 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I have a 77 truck small block exhaust manifold here, at the widest point, right against the flat flange, the bell measures 2 1/2". Usually the pipe doesn't fit up against the flat. I'd say a 2" pipe has a 2 1/4" to a 2 3/8" bell on the pipe. No pies here to measure. Gene
Re: diameter of LA SB exhaust manifold ball? [Re: poorboy] #2191769
11/07/16 09:32 PM
11/07/16 09:32 PM
Central Valley, CA.
Central Valley, CA.
Thanks Gene...exactly what I was looking for! up
