Re: T/A Challenger Replica Project
[Re: Finoke]
#219076
05/02/10 09:12 AM
05/02/10 09:12 AM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
Thanks Tom. I'm hoping to make some real progress over the next 3 months. Other than the paint and bodywork, I still have a few major tasks. I need to rebuild the rear axle, steering column, and suspension. Also need to polish the bright trim.
65 Barracuda 70 Challenger
[Re: jrwoodjoe]
#219077
05/02/10 09:20 AM
05/02/10 09:20 AM
Posts: 4,105 Horsham, Pa.
Finoke
Horsham, Pa.
Will you be rebuilding the rear yourself? I've always been afraid to try that.
[Re: Finoke]
#219078
05/04/10 02:54 PM
05/04/10 02:54 PM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
I can do everything except rebuilding and setting up the pumpkin. I bought a used sure-grip unit and have a new set of 3:55 gears. I'll probably pull the axles and take the pumpkin with the sure-grip to someone local. I'll have them install the new gears, put in new bearings and set the backlash. I'll pull the axles, put in new bearings and reassemble everything. Once it's back together, I'll paint and detail the whole assembly.
Joe
[Re: jrwoodjoe]
#219079
05/07/10 06:56 AM
05/07/10 06:56 AM
Finoke
Horsham, Pa.
Joe
I like that. I might do that next time. Doing it this way gets your feet wet on how things work back there ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: jrwoodjoe]
#219083
06/04/10 01:09 PM
06/04/10 01:09 PM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
[Re: jrwoodjoe]
#219089
07/16/10 09:09 AM
07/16/10 09:09 AM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
Now that all the removable panel rust repair has been competed, it is time to do the body shell. It left yesterday for rust repair and I'll update with those pics as I can. With the car gone, the garage can get reorganized and I'll have room to work on some of the other resto. tasks that need to be done.
Joe
