Page 1 of 3 1 2 3
which rod for a bracket motor #2189688
11/04/16 09:41 PM
11/04/16 09:41 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
i'm upgrading my combo, time to ditch the old rods & step up to something newer & stronger. I'm looking for a set of 6.535 rods to suit my stroker, HP is around 900, reving to 8k. what do you guys feel would be a good reliable rod to fit this combo?
Re: which rod for a bracket motor [Re: rebel] #2189737
11/04/16 10:36 PM
11/04/16 10:36 PM
dogdays Offline
dogdays  Offline
http://www.dragracecarparts.co/oliver-billet-i-beam-connecting-rods-bb-chevy-6-535-length-c6535bb8/
If cost is no object here they are. Callies Ultra would also be there, as would Crower or Carillo.
But realistically you could probably run Scat or Eagle H-beams or Molnar or Compstar or K1 or 440Source, no problem.
The real question is your rpm is 8000, what is your stroke and how much does the piston/pin weigh? The inertia loading at the top of the exhaust stroke is what kills rods, that and detonation.
R.
Re: which rod for a bracket motor [Re: rebel] #2189742
11/04/16 10:40 PM
11/04/16 10:40 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've been very happy with Molnar. Call Tom and give him your stroke, piston/pin/ring weight, and desired RPM level. He'll give you an honest answer. Mine were $579 shipped. The weight was light, tolerances were with-in .0001"
Doug
Re: which rod for a bracket motor [Re: rebel] #2189758
11/04/16 11:00 PM
11/04/16 11:00 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
I've got a set of GRP rods mated to a set of Ross pistons that lived @ 8200 rpm, in a 408 cu.in 440-1C headed motor, injected on alcohol.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: which rod for a bracket motor [Re: rebel] #2189776
11/04/16 11:32 PM
11/04/16 11:32 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
GRP here
Re: which rod for a bracket motor [Re: rebel] #2189897
11/05/16 08:47 AM
11/05/16 08:47 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
To be honest, I cant see myself using Scat, Eagle & definately not 440 Source rods in a 900 HP engine. I'm also leaning toward Steel rods so GRP's are out too. Never seen Molnar rods so i'm not sure how strong they are, i know theyre lighter but are they as strong as Compstars?
My pistons are custom Ross pieces @ 4.400 dia. with their generic pins running at 12.5 compression running on on gas, no spray.
i remember a few years back someone did a comparrission test of the different rods, anybody have a link to that?
Re: which rod for a bracket motor [Re: rebel] #2189915
11/05/16 10:14 AM
11/05/16 10:14 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
questions about Molnar rods? Call Tom himself.
Re: which rod for a bracket motor [Re: rebel] #2189923
11/05/16 10:46 AM
11/05/16 10:46 AM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
Oliver make good rods also up
Re: which rod for a bracket motor [Re: rebel] #2189928
11/05/16 10:54 AM
11/05/16 10:54 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Had real good luck with compstar rods.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: which rod for a bracket motor [Re: rebel] #2189959
11/05/16 12:09 PM
11/05/16 12:09 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
The molnars come with ARP2000 bolts as well. The machining is very nice and for the price I think they are a bargain.
Re: which rod for a bracket motor [Re: rebel] #2189995
11/05/16 01:10 PM
11/05/16 01:10 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Local racer around here has an 8 second w8 barracuda. He broke a molnar Rod in it
1.41 best 60 foot
6.56 at 104.17
Re: which rod for a bracket motor [Re: B3422W5] #2190006
11/05/16 01:25 PM
11/05/16 01:25 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Lol. Some guys can break anything and lots of issues can too. High rpm, bad engine building technics, oiling issues, and MANY more. Some guys shift at 8000 rpm without ever trying 7000 rpm
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: which rod for a bracket motor [Re: B3422W5] #2190017
11/05/16 01:37 PM
11/05/16 01:37 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Im sure someone some where in the world has broke a Oliver rod as well. Just sayin
Re: which rod for a bracket motor [Re: rebel] #2190022
11/05/16 01:42 PM
11/05/16 01:42 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Most of the broken rods I see are from spun bearings (from tight oil clearance), or locked wrist pins, same issue, too tight.
Re: which rod for a bracket motor [Re: dthemi] #2190026
11/05/16 01:45 PM
11/05/16 01:45 PM
PA.
"Little"John
"Little"John
PA.
Or people that think because an engine block coming from a machine shop LOOKS clean, it is clean.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: which rod for a bracket motor [Re: pittsburghracer] #2190095
11/05/16 03:27 PM
11/05/16 03:27 PM
Valid point up
Engine assembly is like brain surgery, it is absolutely freaking impossible to keep it to clean work
Re: which rod for a bracket motor [Re: J_BODY] #2190151
11/05/16 05:36 PM
11/05/16 05:36 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
the thing about asking the seller is sometimes they'll just tell you want you want to hear, bit like car salesmen. Hence this is why i'm asking here so i can get some real world experiances on the different brands. Unfortunately you have to weed thru the folk that know what theyre talking about & those who only have an opinion because they have that brand & they consider it to be the bomb, even if theyre not using it to the capacity i want to be. maybe i should have done a post on 900HP engines & asked what rods they used & for how long they've run them?
Re: which rod for a bracket motor [Re: rebel] #2190170
11/05/16 06:01 PM
11/05/16 06:01 PM
PA.
"Little"John
"Little"John
PA.
The more info you provide in your post the better replies you will get back. Garbage in, garbage out
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: which rod for a bracket motor [Re: rebel] #2190177
11/05/16 06:07 PM
11/05/16 06:07 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Crower or Carrillo.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: which rod for a bracket motor [Re: rebel] #2190183
11/05/16 06:18 PM
11/05/16 06:18 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
your possibly right Pittsburgh, but i thought 900 HP & 8k rpm limit might have reduced the possible options for good answers. i guess i need to be more specific even with that info.
so looking for...
6.535 length STEEL H beam rods
900HP power output
8000 rpm limit
565grm Custom Ross Pistons
No spray
4.250 stroke
am i missing anything?
Page 1 of 3 1 2 3
