Re: Another new challenger to be not impressed with...
[Re: 1967dartgt]
#2190443
11/06/16 12:40 AM
11/06/16 12:40 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
[quote=1967Find me one mopar race car that goes 200+ with a production block! [/quote] That was my point, it seemed that you were implying it was by your threads title, bouncing off of your last hellcat challenger thread. Your Hellcat record, thread as backup of sorts I guess. That lots dismissed because the use of nitrous, witch eliminates a stock scenario. People weren't impressed because it was no longer a stock Hellcat, because of nitrous, as it was implied. So this thread was a response to that, another challenger to be not impressed with. Not even Close to being in the same category or for comparison. Just trying to keep the records straight.
[Re: ksj]
#2190465
11/06/16 01:02 AM
11/06/16 01:02 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Im pretty sure that class you can run billet or billet heads but not both. You are correct
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: ksj]
#2190466
11/06/16 01:03 AM
11/06/16 01:03 AM
1967dartgt
Hilltown Pa
And IIRC the stock block went in the high 6s in the 1/4 on 275s. Yes you are correct by also came apart.
[Re: 1967dartgt]
#2190557
11/06/16 10:42 AM
11/06/16 10:42 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Yep it is a CAST solid Block with billet Thiteks. It also has dual belt driven dizzys,and is a BES combo. It's bad, but it's also pretty basic really, just quality in materials and the car is setup excellent. Thing makes the most uneventful passes I've ever seen at the speeds he's going.
Mopar to the bone!!!
[Re: 1967dartgt]
#2190663
11/06/16 01:20 PM
11/06/16 01:20 PM
Posts: 4,213 New York
polyspheric
New York
Good chance that the Supra (that's a 3.0 = 183" L6 engine designed in 1990, probably also in several of the other import chassis) is using the original block, crank, oil system, pan, head, and valves (there are no rockers, adjusters or pushrods), and drove the car home with the same gearing.
Boffin Emeritus
[Re: 72Swinger]
#2190901
11/06/16 08:22 PM
11/06/16 08:22 PM
1967dartgt
Hilltown Pa
Yep it is a CAST solid Block with billet Thiteks. It also has dual belt driven dizzys,and is a BES combo. It's bad, but it's also pretty basic really, just quality in materials and the car is setup excellent. Thing makes the most uneventful passes I've ever seen at the speeds he's going. I think he has the new victory heads on it.
[Re: 1967dartgt]
#2190972
11/06/16 10:05 PM
11/06/16 10:05 PM
72Swinger
Nebraska
I know they are Billet, and assumed it was Thitek.
[Re: 1967dartgt]
#2191064
11/06/16 11:37 PM
11/06/16 11:37 PM
1967dartgt
Hilltown Pa
HHP has new victory heads out, so I think he switched this year.
[Re: polyspheric]
#2191086
11/06/16 11:58 PM
11/06/16 11:58 PM
Posts: 725 Southern Alberta
Uberpube
Southern Alberta
Good chance that the Supra (that's a 3.0 = 183" L6 engine designed in 1990, probably also in several of the other import chassis) is using the original block, crank, oil system, pan, head, and valves (there are no rockers, adjusters or pushrods), and drove the car home with the same gearing. Engine 3.4L 2JZGTE (87mm bore, 94mm stroke, 9.5:1 compression); Crower billet 4340 crankshaft; Carrillo H-beam connecting rods; CP pistons; Hastings piston rings; Moroso oil pan; Headgames race port, half-inch head studs, headgasket, machining for cam lobes; Crane cams; Ferrea +1mm intake and exhaust valves; Accufab throttle body; Fidanza cam gears; Accelerated Performance intake manifold, exhaust, intake, water-to-air intercooler, intercooler piping, custom Nitrous Express direct-port nitrous injection, custom Peterson dry-sump oiling system; Precision Turbo GT55-91 turbocharger; Full Race T6 Gen. 2 manifold; Tial 50mm blow-off valves (x2), 44mm wastegates (x2); Motec M800 ECU, CDI8 ignition; AFCO radiator; Aeroquip radiator hoses; Flex-a-lite fans; Earl's transmission coolers; Tuning Concepts tuning; Bosch 150lb/hr fuel injectors; Weldon fuel pressure regulator, fuel pump; Ross Machine fuel rail; Painless wiring Drivetrain TH400 transmission, re-built by Rossler Transmissions; Driveshaft Shop Stage 6 axles; TRD limited slip differential; B&M Carbon X shift lever; Neil Chance torque converter
[Re: Uberpube]
#2191457
11/07/16 02:30 PM
11/07/16 02:30 PM
1967dartgt
Hilltown Pa
Good chance that the Supra (that's a 3.0 = 183" L6 engine designed in 1990, probably also in several of the other import chassis) is using the original block, crank, oil system, pan, head, and valves (there are no rockers, adjusters or pushrods), and drove the car home with the same gearing. Engine 3.4L 2JZGTE (87mm bore, 94mm stroke, 9.5:1 compression); Crower billet 4340 crankshaft; Carrillo H-beam connecting rods; CP pistons; Hastings piston rings; Moroso oil pan; Headgames race port, half-inch head studs, headgasket, machining for cam lobes; Crane cams; Ferrea +1mm intake and exhaust valves; Accufab throttle body; Fidanza cam gears; Accelerated Performance intake manifold, exhaust, intake, water-to-air intercooler, intercooler piping, custom Nitrous Express direct-port nitrous injection, custom Peterson dry-sump oiling system; Precision Turbo GT55-91 turbocharger; Full Race T6 Gen. 2 manifold; Tial 50mm blow-off valves (x2), 44mm wastegates (x2); Motec M800 ECU, CDI8 ignition; AFCO radiator; Aeroquip radiator hoses; Flex-a-lite fans; Earl's transmission coolers; Tuning Concepts tuning; Bosch 150lb/hr fuel injectors; Weldon fuel pressure regulator, fuel pump; Ross Machine fuel rail; Painless wiring Drivetrain TH400 transmission, re-built by Rossler Transmissions; Driveshaft Shop Stage 6 axles; TRD limited slip differential; B&M Carbon X shift lever; Neil Chance torque converter OH BOY TWO POWER ADDERS!!!!!!!! That's not good...... just not impressed.....
[Re: Uberpube]
#2191610
11/07/16 05:24 PM
11/07/16 05:24 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Good chance that the Supra (that's a 3.0 = 183" L6 engine designed in 1990, probably also in several of the other import chassis) is using the original block, crank, oil system, pan, head, and valves (there are no rockers, adjusters or pushrods), and drove the car home with the same gearing. Engine 3.4L 2JZGTE (87mm bore, 94mm stroke, 9.5:1 compression); Crower billet 4340 crankshaft; Carrillo H-beam connecting rods; CP pistons; Hastings piston rings; Moroso oil pan; Headgames race port, half-inch head studs, headgasket, machining for cam lobes; Crane cams; Ferrea +1mm intake and exhaust valves; Accufab throttle body; Fidanza cam gears; Accelerated Performance intake manifold, exhaust, intake, water-to-air intercooler, intercooler piping, custom Nitrous Express direct-port nitrous injection, custom Peterson dry-sump oiling system; Precision Turbo GT55-91 turbocharger; Full Race T6 Gen. 2 manifold; Tial 50mm blow-off valves (x2), 44mm wastegates (x2); Motec M800 ECU, CDI8 ignition; AFCO radiator; Aeroquip radiator hoses; Flex-a-lite fans; Earl's transmission coolers; Tuning Concepts tuning; Bosch 150lb/hr fuel injectors; Weldon fuel pressure regulator, fuel pump; Ross Machine fuel rail; Painless wiring Drivetrain TH400 transmission, re-built by Rossler Transmissions; Driveshaft Shop Stage 6 axles; TRD limited slip differential; B&M Carbon X shift lever; Neil Chance torque converter sounds stock but I have never owned a Supra
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#2192132
11/08/16 12:51 PM
11/08/16 12:51 PM
Posts: 4,255 Canada
WO23Coronet
Canada
Good chance that the Supra (that's a 3.0 = 183" L6 engine designed in 1990, probably also in several of the other import chassis) is using the original block, crank, oil system, pan, head, and valves (there are no rockers, adjusters or pushrods), and drove the car home with the same gearing. Engine 3.4L 2JZGTE (87mm bore, 94mm stroke, 9.5:1 compression); Crower billet 4340 crankshaft; Carrillo H-beam connecting rods; CP pistons; Hastings piston rings; Moroso oil pan; Headgames race port, half-inch head studs, headgasket, machining for cam lobes; Crane cams; Ferrea +1mm intake and exhaust valves; Accufab throttle body; Fidanza cam gears; Accelerated Performance intake manifold, exhaust, intake, water-to-air intercooler, intercooler piping, custom Nitrous Express direct-port nitrous injection, custom Peterson dry-sump oiling system; Precision Turbo GT55-91 turbocharger; Full Race T6 Gen. 2 manifold; Tial 50mm blow-off valves (x2), 44mm wastegates (x2); Motec M800 ECU, CDI8 ignition; AFCO radiator; Aeroquip radiator hoses; Flex-a-lite fans; Earl's transmission coolers; Tuning Concepts tuning; Bosch 150lb/hr fuel injectors; Weldon fuel pressure regulator, fuel pump; Ross Machine fuel rail; Painless wiring Drivetrain TH400 transmission, re-built by Rossler Transmissions; Driveshaft Shop Stage 6 axles; TRD limited slip differential; B&M Carbon X shift lever; Neil Chance torque converter sounds stock but I have never owned a Supra "Just your basic JDM bro, wait til the VTEC kicks in"
