Hughes CNC head porting
#2188348
11/02/16 10:10 PM
11/02/16 10:10 PM
Posts: 1,487 STL
cdstl
STL
I live about 2 hours from Hughes. They have a sale going on right now on CNC head porting for Eddy heads. The sale price is just a tad over $1000. It'll cost an extra $100 to get the heads milled to bring the chamber back to 65cc from the 71cc after porting. At .500 lift it shows the flow increasing from 240 cfm stock to around 296 cfm. I'm really thinking hard about but I would have to pull the heads this weekend and run them up on Monday. The sale is based on the election. If Hillary wins it ends November 9th. If Donald wins it ends December 9th. I figured I'd hedge my bets and get them up there early. Has anyone run CNC ported Eddy heads? Hughes CNC sale
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Hughes CNC head porting
[Re: cdstl]
#2188350
11/02/16 10:15 PM
11/02/16 10:15 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
I would have Modern do them.
[Re: B3422W5]
#2188366
11/02/16 10:34 PM
11/02/16 10:34 PM
Posts: 4,693 Wichita
GY3
Wichita
I would have Modern do them. Ditto. Cost me $750 to have my Stealths done there. Quick turnaround too! Supposedly the same program for Eddys and Stealths. See results below
[Re: cdstl]
#2188379
11/02/16 10:45 PM
11/02/16 10:45 PM
Posts: 1,487 STL
cdstl
STL
This is going from 2.02 valves to 2.08, new guides and a valve job.
This is a pair of fully CNC ported USED Edelbrock RPM small block heads supplied by you, the customer.
What's Included: CNC porting, Racing Valve Job and detail finish work Extra clearancing of pushrod tunnels One piece stainless valves. 2.08” intake and 1.60” exhaust with 11/32” stems .550” Phosphor-bronze valve guides Interlocking, ductile iron valve seats Heat treated, machined steel retainers (HUG 1205) Hughes 1129 springs, locks & seals assembled on the heads. (Optional spring upgrades available. Call for details) What’s NOT included: Milling the heads back to original CC’s (Available at an extra charge. Call for details) Spring upgrades
[Re: cdstl]
#2188389
11/02/16 10:59 PM
11/02/16 10:59 PM
B3422W5
Portage,michigan
That " deal" is as much as it would be at Modern normally. And I know guys running heads he did that make good power.
[Re: Jwilli500]
#2188806
11/03/16 03:53 PM
11/03/16 03:53 PM
BradH
Boy! That 50% off CNC porting banner on the front page sure is misleading... Caveat emptor --> Read ALL the details of the sale. Not "misleading", just not what many (most?) people WANT it to mean. It used to be a better deal when they paid for shipping, too.
[Re: AndyF]
#2189259
11/04/16 09:39 AM
11/04/16 09:39 AM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
150+ mph at PIR and the guy drove it to work. that is tuff ,like to here the rest of the combo
[Re: cdstl]
#2189370
11/04/16 12:43 PM
11/04/16 12:43 PM
Posts: 4,209 New York
polyspheric
New York
Driving a 150+ car to work is work if it's NA. Turbo: piece of cake.
Boffin Emeritus
[Re: Ian]
#2189446
11/04/16 02:11 PM
11/04/16 02:11 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
150+ mph at PIR and the guy drove it to work. that is tuff ,like to here the rest of the combo I don't think that 150 was a drag strip 1/4-mile speed. The exit of turn 9 is very near the start of the drag strip and that speed was probably well past the 1/4 mile speed trap. The drag strip is the straight portion of the road course.
