Re: 69 superbee electrical problem
[Re: superbee69]
#2188079
11/02/16 03:25 PM
11/02/16 03:25 PM
RapidRobert
with a reasonably charged battery start by taking off a cable at night from its post & touching it back to the post & see if there is a spark (with doors shut/everything off there should not be any draw unless you have a clock or a lighted stereo faceplate or similar). then we can check if the blue wire field circuit is grounded including the alt field terminals. is the reg an OE type with the wire would resistors on the bottom side?
[Re: RapidRobert]
#2188086
11/02/16 03:37 PM
11/02/16 03:37 PM
Posts: 290 Dayton, WA
wesgtx440
Dayton, WA
The bulkhead connections are a weak link in the electrical system- dirty, loose, or corroded connections will contribute to high resistance, which leads to heat, which can contribute/lead to a meltdown as you described. If all other components check out fine and nothing failed, then that is a likely culprit. Also check the connections on the back of the amp gauge.
68 Charger R/T 440 auto
[Re: superbee69]
#2188219
11/02/16 07:27 PM
11/02/16 07:27 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
Check your underdash harness , when the alt goes dead short like that it's usually melts the main wire to the amp gauge , also check and make sure it wasn't the amp gauge that caused the short.
[Re: superbee69]
#2188225
11/02/16 07:32 PM
11/02/16 07:32 PM
RapidRobert
take the batt cables off of their posts and then keeping the positive cable you just removed from touching anything while it is dangling and with the black wire still off of the alt "batt" threaded stud like you did, see if the black wire has continuity to ground with your meter on ohms. with the black wire off of the alt batt stud, see if the stud itself has continuity to the nearby alt case (it should not)
