Re: Anyone made their own hydro booster kit?
[Re: Pyper70]
#218805
02/11/09 01:01 PM
02/11/09 01:01 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
I guess I need to see some pictures, schematics, and installation components/procedures better educate myself on this
Next time you are in Torrance, you can check out my truck. ![](/ubbthreads/images/graemlins/biggrin.gif)
Basically, power steering pump to hydroboost, hydroboost to steering box. return line from each back to power steering pump. hydroboost mounts to firewall same as a brake booster would basically.
I will take you up on that Oz...Wish I still had my Six to go and play with yours....
I don't have mine any longer either..so don't feel too bad ![](/ubbthreads/images/graemlins/tongue.gif)
Building up the other car now...once it's done I will build another hemi-6 powered Oz Valiant though ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: TheRamMan]
#218807
02/11/09 07:57 PM
02/11/09 07:57 PM
OzHemi
Garden Grove, CA
I AM WORKING ON A KIT ..IF YOU DONOT HAVE A SUPREME PUMP ( DESIGNED FOR THIS) you can be let down..DONT THINK YOUR GOONA RUN SOME LINES OFF YOUR OLD 1968 PUMP AND WALLA MASSIVE POWER ASSIST
THERE IS NO NEED TO YELL ![](/ubbthreads/images/graemlins/no.gif)
Caps lock....know it, use it, live it.
[Re: Jerry]
#218809
02/11/09 10:08 PM
02/11/09 10:08 PM
Posts: 584 San Jose, CA
Blue69Charger
San Jose, CA
I made my own hydroboost kit for my 69 charger. I used a booster off a astro van. It was in excellent shape for $50. I think it was a '98 or a '01, but its been a while so I don't remember. I used a early 90's C3500 master cylinder with a 1" bore. They used an identical looking master cylinder in the dodge rams of similar years but the dodge master cylinders had metric fittings and the chevrolet had english threads. You will have to machine the bracket or make a spacer. If not you will have to modify the hole in your firewall to get the proper alignment. I used a aftermarket clevis and threaded the shaft on the hydroboost. I got the tool to remove the nut on the hydroboost from factory five racing for about $20. I used russell hoses and fittings. Overall I think I spent about $250 for the raw materials and parts. I don't have any drawings or notes anymore, but you can try checking with Ira. He and I were working on our conversions at the same time. The reason I installed it was because I have 4 wheel disc and little vacuum. It works great and can easily lock the wheels. Edit: I found my old post that give more information on the conversion. https://board.moparts.org/ubbthreads/show...rue#Post2750102
[Re: 69charger440_6pa]
#218810
02/11/09 10:12 PM
02/11/09 10:12 PM
Posts: 2,064 MD
RTSE4ME
MD
I have wanted to add a hydro-boost brake booster for some time now, but I really dont want to pay the 700-900 for a kit. Has anyone done their own? You can pick up rebuilt boosters for about $120 and possibly just have to fab up a braket or to.
So has anyone done this?
I have the Hydratech kit on my Challenger with a AndyFs Viper front brake kit. When I bought my kit it was less than $500 and the customer service was great. I think you have to purchase through his dealers now since he could not keep up with all the orders and tech support.
The only draw back to hydroboost is pedal feel is not very good.....hard to modulate the brakes. My car stops very well and one has to be careful so not to put your head thru the windshield
#218815
12/18/13 03:21 PM
12/18/13 03:21 PM
Posts: 28 America
bambi
America
It's been a few years, but I researched this heavily. A guy on Ebay was selling rebuilt Hydro boosters in a kit which included the mounting bracket and all fasteners. I can't remember if he was selling the adjustable plunger rod. Seems like I had to find that on my own. I bought a new aluminum master cyl. (I think 15/16") (or it might have been over 1") There are kits you can buy for close to $1000, or you can make your own. There are plenty of sites on the web to show you how to do it cheaply. I never found a "high output" power steering pump for a Mopar. I haven't installed mine yet. I may try to use a late model Jeep power steering pump. I was going to put it on my 67 Coronet, but am now going to put it on my Challenger. Seems that every Ford hydro unit had the mounting flanges straight up and down. I don't know how you would mount them easily. GM has horizontal mounting flanges, making it much simpler. The set I have looks very nice, factory brand new looking. It even has the firewall mount pre-attatched to the booster body. Very complete, even with the rubber boot for the rod, nylock nuts and ALL assorted hardware needed. It did NOT come with pump, hoses or Master cyl. Or instructions. Lol, I just looked at the kit to refresh my memory. Sorry. I can't remember the Ebay vendors name. It was a fraction of the price of all those popular pre made "kits" on the market. Only a couple of hundred bucks.
[Re: Pyper70]
#218816
12/18/13 03:26 PM
12/18/13 03:26 PM
Posts: 28 America
bambi
America
So you can't really use this hydro-boost on a vehicle that has a Vacuum booster because the cam is really lopey, runs 2 canisters AND had vacuum headlights.....right?
Hydro Boost SOLVES low vacuum brake problems caused by big cams. You are using power steering fluid to run your brake system assist INSTEAD of vacuum. You actually remove your vacuum booster and mount the Hydro Boost directly to the firewall. It can give you much needed valve cover clearance.
[Re: bambi]
#218817
12/18/13 05:24 PM
12/18/13 05:24 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
The pump you want is a mid 80's to late 90's GM 3500 series diesel, it is a Saginaw pump with 2 return lines on the reservoir. Mounts the same as any other sag pump. You also don't need a high output pump, the brakes done use much volume. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
