05 dodge truck fuel pump outlet o ring #2187449
11/01/16 03:54 PM
11/01/16 03:54 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
My oring is leaking fuel out the outlet of the fuel pump. Of coarse I broke the cheap plastic clip that holds it on. The oring is dealer only and cost $40. The clip is 10 more. Any one know of a cheaper source than the dealer?
Re: 05 dodge truck fuel pump outlet o ring [Re: fastmark] #2187573
11/01/16 07:03 PM
11/01/16 07:03 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Well seems like the parts man was new and you can't just buy the o ring and clip. You have to buy the whole fuel line and drop the tank to change it. I'm not even sure it's the fitting. It may be a cracked fuel pump! I think will take off the bed and work from the top. Now I did see a utube video where the guy cut a 22" x 12" hole in the bed for access😳.
Re: 05 dodge truck fuel pump outlet o ring [Re: fastmark] #2190282
11/05/16 08:59 PM
11/05/16 08:59 PM
md
mopars4ever Offline
mopars4ever  Offline
md
My 06 fuel pump was cracked on top and it didn`t leak gas but it did throw codes for the evap. The fuel line clips were available thru dorman. I dropped my tank. Hardest part was emptying the tank.
Re: 05 dodge truck fuel pump outlet o ring [Re: fastmark] #2197251
11/16/16 10:09 AM
11/16/16 10:09 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
$40?! I bought one for my 98 Dakota from the local dealer for $10 after tax. Is that different than the 05s?
**Photobucket sucks**
Re: 05 dodge truck fuel pump outlet o ring [Re: fastmark] #2197461
11/16/16 06:25 PM
11/16/16 06:25 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Well. I don't know. They don't sell just the o ring. I'll pull the bed in a few weeks and check it out before I order anything. I have my lift tied up at the moment.
Re: 05 dodge truck fuel pump outlet o ring [Re: fastmark] #2874067
01/14/21 12:00 AM
01/14/21 12:00 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
More times than not the fuel pump is cracked.....
