Re: Fusible link blew
[Re: glenngomango]
#2187361
11/01/16 01:55 PM
11/01/16 01:55 PM
Posts: 954 Chicago
PurpleBeeper
Chicago
I had some electrical problems many years ago that blew my fusible link. I installed a regular fuse holder in that location & carried fuses with me for about 2 yrs. until I finally redid the dash wiring.
All the power for the car except starter & headlights (I think) goes through that wire, so your short could be just about anywhere and blow that link. You'll have to track down the short.
I used to think about making my car "stealth" by putting a switch inline with that fusible link wire & one more in the brake light circuit. Turn off those two switches & only the headlights & engine get power....not that anyone would ever need that
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: glenngomango]
#2187362
11/01/16 01:57 PM
11/01/16 01:57 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Check voltage at coil positive for power with a meter or test lite. With ignition switch in run position. No power, work backward thru wiring to ignition switch.
If power, check distributor condenser, wiring, points,,,,if you have factory system.
If all well, get back to us for more.
[Re: Sxrxrnr]
#2187384
11/01/16 02:38 PM
11/01/16 02:38 PM
RapidRobert
What Sxr said, it died in ign1 "run" so with key on see if the coil positive primary terminal is hot and if converted to electronic ign see if the blue/yellow terminal at the ECU pentastar connector is hot also. I'm assuming you checked the AP for a squirt
[Re: glenngomango]
#2187647
11/01/16 09:01 PM
11/01/16 09:01 PM
Posts: 43,119 Bend,OR USA
Cab_Burge
Look very closely at all the wiring harnesses, engine harness, front light harness, rear taillight harness and so on, Look for melted tape Once you find that your on the right tack to fixing it, especially under the dash and the engine compartment The bulkhead connections can corrode and cause a high resistance which will make the alternator over charge, same thing on the back nuts on the amp gauge, they can vibrate loose and cause the same thing Let us know what you find
