Help removing torsion bar #218653
02/09/09 11:44 AM
02/09/09 11:44 AM
Hunt Valley, Maryland
1fastrunner Offline OP
Trying to get my engine out the bottom, and of course I've already hit a hurdle. I removed the front nuts, rings, and seals from the torsion bar up front. I've taken the load off and removed the back nuts. Am I missing something else, or maybe some tricks? Dumb question, does it come out the front or the back of the lower control arm.
Thanks,
Re: Help removing torsion bar [Re: 1fastrunner] #218654
02/09/09 11:48 AM
02/09/09 11:48 AM
ga
ringo440 Offline
ringo440  Offline
ga
The back
Re: Help removing torsion bar [Re: ringo440] #218655
02/09/09 11:51 AM
02/09/09 11:51 AM
That's what I thought, but it's not budging. I thought for a second I could be wrong, I've been wrong on more obvious things in the past.
Re: Help removing torsion bar [Re: 1fastrunner] #218656
02/09/09 11:56 AM
02/09/09 11:56 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
there is a tool that clamps on the torsion bar, make sure the bolt that loads the bar is back all the way off, and the lower control arm nut is really loose. there is also a clip in the rear
Re: Help removing torsion bar [Re: 1fastrunner] #218657
02/09/09 11:58 AM
02/09/09 11:58 AM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
when i removed mine, I unbolted the lower control arm and the wedged it and the torsion bar back. It then came out of the back of the sockets (since the clips were removed) and from there on was extremely easy to get out.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Help removing torsion bar [Re: 70blackfish] #218658
02/09/09 12:01 PM
02/09/09 12:01 PM
I didn't see a clip. I took off the load, and removed the nut completely from the lower control arm end. Maybe the clip is the problem. Can you please explain?
Re: Help removing torsion bar [Re: 1fastrunner] #218659
02/09/09 12:08 PM
02/09/09 12:08 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Look for one of those clips against the back of the torsion bar where it will slide out.
Ride eternal, shiny and chrome
Re: Help removing torsion bar [Re: 1fastrunner] #218660
02/09/09 12:09 PM
02/09/09 12:09 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Look at the back end of the bar in that recessed area there will be a wire clip that fits in a slot. You need to remove it. You may have to clean out the recess to see it.
Re: Help removing torsion bar [Re: DirectSubjection] #218661
02/09/09 12:25 PM
02/09/09 12:25 PM
When you say the back of the torsion bar, is it by the boot near the radiator (front)?
I did get the bar to rotate.
Re: Help removing torsion bar [Re: 1fastrunner] #218662
02/09/09 12:28 PM
02/09/09 12:28 PM
Here
Here
No - out the back of the K-frame by the trans. Look in the holes, remove them with pliers, then slide the bars out the same way.
Re: Help removing torsion bar [Re: 1fastrunner] #218663
02/09/09 12:30 PM
02/09/09 12:30 PM
DFW
68RRFlyer Offline
68RRFlyer  Offline
DFW
Put your head under the car aft of the trans crossmember (where the driveshaft enters the trans). Look forward at the backside of the transmission crossmember and you'll see two big cylindrical studs about 3" in diameter sticking out towards you. You're now looking at the backside of the torsion bar mounts on the crossmember. There is a small "C" clip that you'd need to remove as pictured in the above post photos located in a recess inside that mount. It's usually greasy and dirty. Remove that clip and scoop out all the grease you can. Sometimes the old grease and crud makes it hard to wiggle out. Not trying to be a smart-alec, but that's the best way to describe where you're not looking!
Cheers
Re: Help removing torsion bar [Re: 68RRFlyer] #218664
02/09/09 01:24 PM
02/09/09 01:24 PM
If this is what you're talking about, I don't see a clip inside?
Re: Help removing torsion bar [Re: 1fastrunner] #218665
02/09/09 01:40 PM
02/09/09 01:40 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Could be the clips are missing...just scrape around with a screwdriver to make sure (through the junk) incase the edge of the clips happened to break off. But that is the right spot for them. Just inside the edge of the socket you should be able to feel the groove the clip goes into.
Re: Help removing torsion bar [Re: OzHemi] #218666
02/09/09 01:44 PM
02/09/09 01:44 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
BTW...could just be that the bars are stuck..I've been lucky that ones I have done have come out easy. I usually just use a bar to pry back abit on the lower control arm (between the arm and K frame, to force it towards the rear) and that is enough to get the torsion bar loose from it's spot and it then slides out. I would try that (you already mentioned having the lower control arm nut off, so that's good) and see if sliding it back abit will break the crud free and get the bar loose.
If you slide it back abit and it still feels tight you'll need a tool to actually knock the bar bar itself.
Re: Help removing torsion bar [Re: OzHemi] #218667
02/09/09 02:13 PM
02/09/09 02:13 PM
I've finally got it to move back to where it's flush at the rear, but it has stopped moving. I try prying the lower control arm next.
Re: Help removing torsion bar [Re: 1fastrunner] #218668
02/09/09 02:16 PM
02/09/09 02:16 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
just yank the K forward and the bars will come out either from the T bar x member or the LCA. Never had one give me too much trouble that way.
Re: Help removing torsion bar [Re: nomore65BelvJim] #218669
02/09/09 02:30 PM
02/09/09 02:30 PM
Well, very frustrating to say the least. It seems to be hung up either on the lca or at the rear. It's moving the lca back when I try to hit the bar back. I can wedge a pry bar between the k frame and the lca, but it does me no good.
Re: Help removing torsion bar [Re: 1fastrunner] #218670
02/09/09 02:43 PM
02/09/09 02:43 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
go to the hardware store and get a cable clamp and use it as a clamping tool and the use a hammer to slide it back and out.
Re: Help removing torsion bar [Re: 70blackfish] #218671
02/09/09 02:48 PM
02/09/09 02:48 PM
Texas
RaiderLefty Offline
RaiderLefty  Offline
Texas
I used the t-bar removal tool from JustSuspension and it worked great. My bars would not budge an inch prior to trying this tool.
Simply clamp around the bar and hit it with a small sledge. After a couple good whacks the bar should break free and slide right out.
Re: Help removing torsion bar [Re: 70blackfish] #218672
02/09/09 02:48 PM
02/09/09 02:48 PM
A cable clamp is what? All I see is a plastic thing for wrapping up cords.
