Re: Fast cars with a third pedal...
[Re: 68LAR]
#2185071
10/29/16 01:33 AM
10/29/16 01:33 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Adding a 3.09 1st just makes the gear spread terrible. I will drive it more than race it If you're putting a lot of power to the overdrive 833, I'm thinking you're going to be disappointed with its longevity. Agreed. Went this route several years back. Actually bent the input shafts twice. Annnnd, I didn't go any faster. Actually went slower. Went back to an 18 spline with 2.65 low and everything is good again. Also, I don't know if they will chime in, but there are 2 other cars that are pretty impressive. My Son's '69 Dart, street car(Lar414), with a 414 stroker has gone deep into the 11's. A good friend of mine, OLDIRON has a '67 Barracuda that has gone low 9.90's. Both cars are very impressive, Just sayin'.......... Did not know "Lar414" was your son. His Dart is really awesome. You and your son have two really cool Mopars that look great and run very good. I belive his Dart was in Mopar Muscle some years back. And I think he put a crossram on it also if I am not right. Like I say you guys have two awesome Mopars that anyone would love to own. Ron
[Re: 72Swinger]
#2185079
10/29/16 01:44 AM
10/29/16 01:44 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
72 Dart, 420" 6.1 Hemi, Viper T56, 3.91s, 335 street tires, 3700lbs with me in it,pump 91, 2300ft above the sea, been to track once and best pass out of 4 was 12.09@121.75 with a lousy 2.0 60ft. Track sucked,runs better on the street. How did you get it so heavy? Sounds like a killer street car. lots of ways lol, 1.75x.120 wall full road race cage, 14" front steel SRT rotors that weigh 30lbs each,full Interior, front and rear swaybars etc. The cage alone is 200 lbs. Used to weigh 3240 with an iron head BB. Wow, seems really cool. Do you think it handles better with the hemi.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Al_Alguire]
#2185101
10/29/16 02:40 AM
10/29/16 02:40 AM
Posts: 11,540 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Check out Tim Riggleman's small block Daytona. In the 7's. Runs with the Pro Stick group. Is this a blue Daytona? Yes.
[Re: 1967dartgt]
#2185108
10/29/16 03:12 AM
10/29/16 03:12 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
72 Dart, 420" 6.1 Hemi, Viper T56, 3.91s, 335 street tires, 3700lbs with me in it,pump 91, 2300ft above the sea, been to track once and best pass out of 4 was 12.09@121.75 with a lousy 2.0 60ft. Track sucked,runs better on the street. How did you get it so heavy? Sounds like a killer street car. lots of ways lol, 1.75x.120 wall full road race cage, 14" front steel SRT rotors that weigh 30lbs each,full Interior, front and rear swaybars etc. The cage alone is 200 lbs. Used to weigh 3240 with an iron head BB. Wow, seems really cool. Do you think it handles better with the hemi. Definitely, car is balanced but needs more rear spring.
Mopar to the bone!!!
[Re: sshemi]
#2186030
10/30/16 06:41 PM
10/30/16 06:41 PM
Posts: 2,128 sweden
sshemi
sweden
[Re: 383man]
#2187326
11/01/16 12:56 PM
11/01/16 12:56 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: taxidermy man]
#2187672
11/01/16 09:39 PM
11/01/16 09:39 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I have in my 67 Barracuda a home built pump gas 505 stroker, Edelbrock heads, 950 HP Holley, American Powertrain Kevlar 11" disc&pressure plate, dana 60 with 4.56 gears. runs 10.30 at 130 What have I broke? The 833, the dana gears, the u-joints and a lot of oil pans
[Re: rowin4]
#2187916
11/02/16 11:02 AM
11/02/16 11:02 AM
OhioMopar
Mt.Gilead, Ohio
I have in my 67 Barracuda a home built pump gas 505 stroker, Edelbrock heads, 950 HP Holley, American Powertrain Kevlar 11" disc&pressure plate, dana 60 with 4.56 gears. runs 10.30 at 130 What have I broke? The 833, the dana gears, the u-joints and a lot of oil pans Nice. As long as the oil pan isn't breaking from parts flying through it, that's ok, right?
[Re: OhioMopar]
#2187947
11/02/16 12:05 PM
11/02/16 12:05 PM
rowin4
I have in my 67 Barracuda a home built pump gas 505 stroker, Edelbrock heads, 950 HP Holley, American Powertrain Kevlar 11" disc&pressure plate, dana 60 with 4.56 gears. runs 10.30 at 130 What have I broke? The 833, the dana gears, the u-joints and a lot of oil pans Nice. As long as the oil pan isn't breaking from parts flying through it, that's ok, right? Never , knock on wood put anything through the pan or hurt any bottom end rotating parts , 6800 RPM's at every shift . Pan damage is from wheel stands.
[Re: OhioMopar]
#2189986
11/05/16 12:57 PM
11/05/16 12:57 PM
Posts: 1,505 TN
SCATPACK 1
TN
[/quote] That's cool. Thanks! Sometimes I think I should have gone with a 4.10 over a 3.54 in my Dana. [/quote]
I have a 4.10 Dana in my 70 Challenger RT. It is a bit busy on the street though. I am currently using a OD version of the 833 and it is a good offset of the 4.10 on a road trip. But the gear spread and ratio drops is too excessive. But I will be switching back to my Hemi 4 speed once I am thru with the rebuild to install new bearings and new syncro's. The engine is 440 with MW heads, Indy intake and 1050 2 circuit Dominator. Cam is 258/262@50 w 580/562 lift. The Dana and the leaf springs are from a 69 GTX 4 speed car. Have not had it to the track since I got it back on the road as I am afraid of breaking the OD 4 speed trans. Jerry
Old Geezer Racing
[Re: SCATPACK 1]
#2190535
11/06/16 07:44 AM
11/06/16 07:44 AM
Posts: 2,128 sweden
sshemi
sweden
I really like this Dart. Looks clean and this is an awesome shot Thank you. I pretty much built it all by myself exept the engine. Theres an in car vid on youtube from a tnt day. Search for swede4speed kjula.
[Re: SCATPACK 1]
#2190787
11/06/16 04:35 PM
11/06/16 04:35 PM
383man
Balt. Md
I really like this Dart. Looks clean and this is an awesome shot You said it as thats one nice Dart. Ron
[Re: OhioMopar]
#2194842
11/11/16 04:46 PM
11/11/16 04:46 PM
Posts: 4,009 South Park, Pa.
68LAR
South Park, Pa.
Who's got them? What's your combo? What does it run? What have you upgraded? What have you broken? Thanks! There's got to be more stick cars out there that fit this profile.. Where you at???????
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
