Re: Help needed with rod/ piston selection.
[Re: hudsonhornet7x]
#2185347
10/29/16 03:39 PM
10/29/16 03:39 PM
Posts: 43,123 Bend,OR USA
Cab_Burge
Both are good choices Which pistons and rods are the lightest? I like and use the lightest rods and pistons I can in most cases
#2185449
10/29/16 08:05 PM
10/29/16 08:05 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I have Manley pistons,rods,crank,valves,Springs and pushrods in mine. I'm using Mahle rings though.
Mopar to the bone!!!
#2185486
10/29/16 08:51 PM
10/29/16 08:51 PM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
I'm not a big fan of Ross pistons. My only firsthand experience with them was a bad one. Stock crank 4.6 cobra mustang with stock length aftermarket rods and Ross pistons. You would think that stock crank and length rods would mean the pistons would clear everything, but the skirts hit the counterweights at BDC. A guy who I used to work for tried some in a turbo Buick V6 and couldn't get them to stop scuffing the skirts. He claimed that they kept increasing the bore clearance and it didn't change the results. Take that for whatever it's worth as it's not my first hand experience and I don't know what the combination was entirely. I'm sure there are plenty of people who haven't had any issues either, but I thought I'd share my experience with you anyway. Good luck with whatever you choose. Oh, Ohio crankshaft has a couple choices for cranks as well. Don't know how their quality is, but it's one more option. http://www.ohiocrank.com/mopar_cranks.html
