Re: Fast cars with a third pedal...
[Re: JERICOGTX]
#2194940
11/11/16 09:16 PM
11/11/16 09:16 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
The fellow on the left was fast. Almost like an explosion when he passed by. Skeered me! But then again, fast is relative
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: OhioMopar]
#2195095
11/12/16 11:02 AM
11/12/16 11:02 AM
Posts: 4,066 Mo.
racerx
Mo.
The fellow on the left was fast. Almost like an explosion when he passed by. Skeered me! But then again, fast is relative drive He is fast what kind of car was this?
[Re: racerx]
#2195122
11/12/16 12:23 PM
11/12/16 12:23 PM
oldiron
New Hampshire, USA
it was a fairly serious mustang. I think it had a gforce trans. a couple of fast mopars - mid high 8s both small blocks
[Re: skep419]
#3091050
11/02/22 12:43 AM
11/02/22 12:43 AM
Posts: 7,480 Minnesota
Hemi_Joel
Minnesota
Are we supposed to respond to this Lazarus thread?
Ok, I'll do it. 31 Plymouth coupe, street/strip, completed 2 Drag Weeks, mostly stock except for a stroked early Hemi, 8 Holley 94 carbs, t56 magnum, McLeod RTX clutch, Clutch Tamer, quicktime bell, 4.57 Moser 9" , 4 link, coil overs, 8.50 cage, 2750# at the starting line. Haven't broke anything, gone 10.teens at 137. Still needs a lot of sorting, I expect 9's from it.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#3091053
11/02/22 01:25 AM
11/02/22 01:25 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I guess i fit into this category:
68 charger R/T 505 rb 10.6:1 1050 dom Jerico dr4 4.30 rear gear Leaf spring/caltrac Pretty porky….3900
Runs pretty consistent: 10.75 @ 127
[Re: Chargerfan68]
#3091069
11/02/22 07:12 AM
11/02/22 07:12 AM
Posts: 10,021 MN
JERICOGTX
MN
68 Road Runner.
Old 499ci combo with a Jerico DR4, ran 9.72 @ 138mph.
New combo, with 563ci made 140 more HP, and I switched to a Clutchless Liberty 4 speed. Should run bottom 9's, high 8's on a good day.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3091104
11/02/22 10:27 AM
11/02/22 10:27 AM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
I don't race much anymore but my best pass was 10.91 at 124 in my Savoy. 493 with Indy EZ heads, mild flat tappet cam, 10.9 comp, Richmond 5-speed with faceplate by Liberty's, Long V-gate, 3.54 D-60, Performer RPM with a QF 1050 4150 carb. Older Hays MK XII adjustable plate and Ram bronze disc. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 68LAR]
#3091182
11/02/22 03:07 PM
11/02/22 03:07 PM
Posts: 570 UK
rb446
UK
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: rb446]
#3091230
11/02/22 06:42 PM
11/02/22 06:42 PM
Posts: 5,161 CT
GTX MATT
CT
Mine isn’t as fast as what you’re looking for, but I’ll bite. Mine went 12.57 @ 113 last weekend, with a soft 1.79 60 ft and sloooow shifts. It took 9 passes, but thats the first complete pass the car has run. From here I can try to launch it harder and shift it faster. Do you guys find shifting slow affects trap speed or et more? Combo is stock stroke 440, Racer Brown ST-21 (254 @ .050, 520 lift), 107 LSA, RPM intake with an 850 DP, Stealth heads, 18 spline with a Ram Powergrip HD, and 4.10 8 3/4 (reason for babying the launch and shifts). The last 3 passes the clutch seemed to slip in first, I pedaled it some and it locked up and held for the rest of the run. But I was actually thinking about throwing a 727 in it to see what it runs with it
[Re: GTX MATT]
#3091308
11/03/22 04:36 AM
11/03/22 04:36 AM
Posts: 1,260 Netherlands
72Challenger
Netherlands
In the past (racing is 99% dead over here so meanwhile sold the car) I have gone 8.9's with my Challenger.
Guestimate at around 2900lbs 528 pumpgas, flat tapped cammed, single dominator, Hemi Gforce clutchless 4speed and adj. clutch I believe from Hyatt. Dana60 with 456 gears and 33" slicks.
Had some topend troubles with the engine so was potential a 8.7 I guess.
[Re: cuda499]
#3092576
11/08/22 02:35 PM
11/08/22 02:35 PM
Posts: 782 Minnesota
skep419
Minnesota
Thanks for sharing, looking for inspiration. I'm putting together a 69 Dart stock bottom end/head 5.9 magnum, cam/springs, air gap intake, Centerforce clutch 440 source flywheel, 2.66 23 spline A833, 8 3/4 3.23 gears (I have a complete 3.91 742 center if needed) Hoping it will run in the 7's 1/8.
[Re: viperblue72]
#3093582
11/11/22 10:53 PM
11/11/22 10:53 PM
fourgearsavoy
Rittman Ohio
I have one I still need to sort out. ‘74 cuda, 3650 race weight. 511/trickflow 270, tkx 5-speed. I managed to make a couple easy passes this summer but didn’t have a rollcage yet so I launched and shifted easy. Went 11.26@130.5. https://youtube.com/shorts/sYdGhhFns7g?feature=share How do you like the TKX gearbox? Does the shifter go smooth at high RPM's ? I haven't read many reviews about how they react on the strip with some HP in front of them. Gus
[Re: viperblue72]
#3093741
11/12/22 03:54 PM
11/12/22 03:54 PM
fourgearsavoy
Rittman Ohio
Thanks I have a few of my 833 customers asking me about converting their cars over to some type of OD box. The online claims as to the strength of this box are as usual seem highly inflated. I have built a few T56 transmissions and the design prohibits high speed power shifts even when the gears are face-plated. I may just sell a few of my transmissions and buy one of these boxes as my car is more street than strip right now. I only hope that is will hold up to the torque and weight of my car with sticky tires. I will probably install the adjustable clutch or try one of those Clutch Tamer deals to keep the teeth on the gears. Gus
