Page 1 of 4 1 2 3 4
Fast cars with a third pedal... #2183773
10/27/16 02:13 PM
10/27/16 02:13 PM
Mt.Gilead, Ohio
OhioMopar Offline OP
Mt.Gilead, Ohio
Who's got them? What's your combo? What does it run? What have you upgraded? What have you broken?
Thanks!
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Fast cars with a third pedal... [Re: OhioMopar] #2183810
10/27/16 03:09 PM
10/27/16 03:09 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
What is your definition of fast?
69 GTX 68 Road Runner
Re: Fast cars with a third pedal... [Re: OhioMopar] #2183812
10/27/16 03:11 PM
10/27/16 03:11 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
We'll say 11.80 and faster?? Something that will keep up with a Scatpack on drag radials, for instance? lol
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Fast cars with a third pedal... [Re: OhioMopar] #2183814
10/27/16 03:17 PM
10/27/16 03:17 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
I'll bite.....
440 stroker (493ci)
1050AN Quickfuel 4150 carb
Solid flat tappet cam
Stock NP A833 18 spline
Center force clutch
Dana 60/ 4.56 gears
Total weight with me and 1/2 tank of 93 octane 3926#
Best time is in my sig. Usually runs 11.1's at 123+ thru the mufflers.
Before switching to a Dana, I've broken everything imaginable in an 8 3/4. Twisted housings, U joints, axles, spun purches. Never broke a tranny outright though, but did have collateral damage on one at one time.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Fast cars with a third pedal... [Re: 68LAR] #2183818
10/27/16 03:23 PM
10/27/16 03:23 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Originally Posted By 68LAR
I'll bite.....
440 stroker (493ci)
Center force clutch
Dana 60/ 4.56 gears
That's cool. Thanks! Sometimes I think I should have gone with a 4.10 over a 3.54 in my Dana.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Fast cars with a third pedal... [Re: OhioMopar] #2183825
10/27/16 03:29 PM
10/27/16 03:29 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
3.54' are nice street gears. If you go to the track on occasion, then something in the 4.10 or steeper range would be in line, but again, it would depend on the rest of the combo. Example: if your engine rpm tops out at 5K, then going to a steep gear would make no sense at all. It always come down to combo......
Re: Fast cars with a third pedal... [Re: 68LAR] #2183830
10/27/16 03:37 PM
10/27/16 03:37 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Agreed. Still deciding on a combo. Sold the engine out of my Bee. Now trying to decide what to replace it with.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Fast cars with a third pedal... [Re: OhioMopar] #2183882
10/27/16 04:49 PM
10/27/16 04:49 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
72 Dart, 420" 6.1 Hemi, Viper T56, 3.91s, 335 street tires, 3700lbs with me in it,pump 91, 2300ft above the sea, been to track once and best pass out of 4 was 12.09@121.75 with a lousy 2.0 60ft. Track sucked,runs better on the street.
Mopar to the bone!!!
Re: Fast cars with a third pedal... [Re: 72Swinger] #2183905
10/27/16 05:23 PM
10/27/16 05:23 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
That's cool! I haven't ruled out a Gen III. But I already have a 440 block. A cost comparison is in order, I suppose.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Fast cars with a third pedal... [Re: OhioMopar] #2184196
10/27/16 10:55 PM
10/27/16 10:55 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Check out Tim Riggleman's small block Daytona. In the 7's. Runs with the Pro Stick group.
Re: Fast cars with a third pedal... [Re: CMcAllister] #2184372
10/28/16 09:27 AM
10/28/16 09:27 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Nice.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Fast cars with a third pedal... [Re: 72Swinger] #2184603
10/28/16 03:35 PM
10/28/16 03:35 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
How did you get it so heavy? Sounds like a killer street car.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Fast cars with a third pedal... [Re: CMcAllister] #2184608
10/28/16 03:38 PM
10/28/16 03:38 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Is this a blue Daytona?
Re: Fast cars with a third pedal... [Re: OhioMopar] #2184619
10/28/16 03:46 PM
10/28/16 03:46 PM
I use to drag race several different stick cars, you can change the first gear ratio to make the car leave harder without changing the rear gear scope
IE, we used a early A body NP833 23 spine tranny in my old 340 Duster street and strip stick shift car, the stock first gear ratio in them is 3.09 thumbs work devil
My current street and strip car I'm building now has the O.D. NP 833 tranny with the same first gear ratio and .64 % over drive, I'm using a 3.55 ratio Dana 60 in that car with a 464 C.I. 440 motor on pump gas, hopefully the O.D. tranny will hold up to a little abuse luck
Re: Fast cars with a third pedal... [Re: OhioMopar] #2184689
10/28/16 05:08 PM
10/28/16 05:08 PM
Washington
W
weedburner Offline
weedburner  Offline
W
Washington
I have quite a few Coyote Stock customers. They run at 3000lbs, use a 5.0L 435hp rated factory sealed crate engine, must use a single 10 or 10.5" disc and a diaphragm style pressure plate, spec transmissions/ratios, and must use the clutch to shift. Here's some recent slip data from a run...
1.296
3.868
6.059
110.11
7.968
9.610
134.94
When everybody's making the same power, it can be especially sweet when you get the clutch tune just right. When the clutch hits too hard, it either pulls the engine down too far or knocks the tires loose. Hitting too soft is also counter productive, but there's a sweet spot in between where things work amazingly well. Basically you want to match the clutch's clamp to the engine's power, as this can effectively raise the engine's average rpm, which in turn allows the engine to produce more power in a tighter time frame.
Here's a simplified example to help explain why you want to keep average rpm as high as practically possible-
Lets say a car has the power to gain speed at an average rate of 6000 rpm per second in 1st gear. Let's also have the clutch slip until .5 sec into the run with the tires remaining dead hooked. If the car launches at 6k and the tires are stuck, the clutch will pull engine rpm down to 3k by the .5 sec mark. Then from .5 to 1.0 seconds rpm will climb from 3k back up to 6k, as the engine regains the lost rpm. What all this boils down to is that during the initial 1 second after launch, the engine's average rpm was 4500 rpm, which means the engine made 75 revolutions over that 1st second of the run.
...Now suppose that same car launches at 6k, but now the clutch slips just enough that the engine does not lose any rpm over that same 1 sec period. Now the engine's average rpm was 6000, which means it made 100 revolutions during that initial 1 second period.
...Here's the thing- both left from the same rpm, but the launch that didn't lose any rpm actually packs 33% more revolutions of WOT power production into the same 1 second time period. If the clutch also slips just right after the shifts, you can pick up some power production there as well.
When you understand what you need to do, you can likely make things come together on your own. Here's a few things you can do to an overly aggressive clutch to tweak it closer to that sweet spot...
1- less aggressive friction material
2- smaller diameter disc
3- reduce effective diameter of the disc (trim away some of the friction material's face without reducing overall diameter)
4- reduce clamp pressure either by swapping to a weaker PP/spring, different fulcrum or shimming your existing PP away from the flywheel
5- temporarily hold back some clamp pressure with your foot, basically ride the clutch out for 5-10 feet. Adding an adjustable spring loaded pedal stop can make it easier to consistently find the sweet spot in the pedal travel
6- temporarily hold back some clamp pressure with a timed mechanical device (this is what my device does)
Just putting this out there to show you don't necessarily have to have an "adjustable" clutch to be quick.
Re: Fast cars with a third pedal... [Re: Cab_Burge] #2184759
10/28/16 06:29 PM
10/28/16 06:29 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Adding a 3.09 1st just makes the gear spread terrible. I will drive it more than race it
If you're putting a lot of power to the overdrive 833, I'm thinking you're going to be disappointed with its longevity.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Fast cars with a third pedal... [Re: OhioMopar] #2184769
10/28/16 06:40 PM
10/28/16 06:40 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Agreed. Went this route several years back. Actually bent the input shafts twice. Annnnd, I didn't go any faster. Actually went slower. Went back to an 18 spline with 2.65 low and everything is good again.
Also, I don't know if they will chime in, but there are 2 other cars that are pretty impressive. My Son's '69 Dart, street car(Lar414), with a 414 stroker has gone deep into the 11's.
A good friend of mine, OLDIRON has a '67 Barracuda that has gone low 9.90's.
Both cars are very impressive, Just sayin'..........
Re: Fast cars with a third pedal... [Re: OhioMopar] #2184791
10/28/16 07:21 PM
10/28/16 07:21 PM
Maryland
twayne24365 Offline
twayne24365  Offline
Maryland
looking to do an 833 swap in my dart over the winter! 4 speed has so much more fun factor
Re: Fast cars with a third pedal... [Re: 1967dartgt] #2184798
10/28/16 07:30 PM
10/28/16 07:30 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
lots of ways lol, 1.75x.120 wall full road race cage, 14" front steel SRT rotors that weigh 30lbs each,full Interior, front and rear swaybars etc. The cage alone is 200 lbs. Used to weigh 3240 with an iron head BB.
Re: Fast cars with a third pedal... [Re: OhioMopar] #2184987
10/28/16 11:34 PM
10/28/16 11:34 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
9.97 @ 135 mph 440 915 heads 1050 team G lugged hemi box
[image][/image]
Page 1 of 4 1 2 3 4
