Re: 340 to 360 Engine Swap
[Re: 426Wish]
#2181365
10/24/16 01:01 PM
10/24/16 01:01 PM
Posts: 5,100 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Doesn't the converter need to be balanced to match the 360 rotating assembly since it is externally balanced? I know my 340 converter didn't have any weights on it but I have seen 360 converters with. B+M sells a flex plate that will allow a zero balance convertor to work behind the externally balanced 360...
...FAFO...
[Re: 426Wish]
#2181387
10/24/16 01:25 PM
10/24/16 01:25 PM
RapidRobert
Doesn't the converter need to be balanced to match the 360 rotating assembly since it is externally balanced? the B&M specialty flex plate does exactly that same function, not dead on like it would be if you handed the rotating assy and this flexplate & front dampener to your shop for balancing but it duplicates Ma's factory torque converter balance which is so so but adequate. Order one & you are set. the 340 MAY have slightly different front to rear spacing of the block mtr mt lugs on the DR side so it MAY take a different mount. the 360 will have a different dampener and pan & other than that they will be externally the same AFAIK. there are (2) "center" sump 360 pans that I am aware of, a 392 and a 876 (stamped on bottom). the sumps on both are ~8" long and the sump bulge starts 4" back from a vertical plumb line straight down from the very front lip on the 392 and 2" back on the 876. both take different pickups (I can dig up pics if needed). grab your tape & measure the 340 pan before you pull it
[Re: 426Wish]
#2181401
10/24/16 01:49 PM
10/24/16 01:49 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
340 and 360 mounts interchange. Oil pan doesn't, but if your donor was a pass car then it should work.
Other than oil pan and external balance, they are a plug and play swap.
[Re: 426Wish]
#2181439
10/24/16 02:24 PM
10/24/16 02:24 PM
RapidRobert
a 360 "weighted" converter will have 2 weights close to each other on the front flat face. any converter may have a thinner weight on the curved back side & reason is that the weight on the curved back side is used to balance the hunk of metal that the converter is when mfr'd to a neutral balance then if it is going to be made into an externally balanced unit for a 360 then 2 weights are additionally added to the front flat face. EDIT yes use a TC with NO weights on the front along with the B&M plate for external balanced setup
[Re: RapidRobert]
#2181510
10/24/16 03:47 PM
10/24/16 03:47 PM
Posts: 25,720 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Some 360LA converters have a single large weight, usually triangular but sometimes square.
[Re: elmor353]
#2182369
10/25/16 06:22 PM
10/25/16 06:22 PM
Supercuda
About to go away
About to go away
up yours
If you have a converter with weights on the front, you don't need to buy a B+M flexplate. Maybe, depends on what it's weighted for. Not all external balance Mopar engines use the same imbalance weight. Assuming the weights you have are right is not a good idea.
[Re: 426Wish]
#2182406
10/25/16 07:08 PM
10/25/16 07:08 PM
Supercuda
About to go away
About to go away
up yours
No problem, it's all good
