Re: Does NHRA allow magnesium wheels? [Re: Hemi_Joel] #2178387
10/19/16 04:41 AM
10/19/16 04:41 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
The Flys are cool........but for what guys ask for them, I have to settle for Bogarts
Re: Does NHRA allow magnesium wheels? [Re: Hemi_Joel] #2178465
10/19/16 11:27 AM
10/19/16 11:27 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
As I recall the stuff can spontaneously combust in water.
I guess you don't ever want to wash your wheels or drive in rain !!!!
Re: Does NHRA allow magnesium wheels? [Re: Stanton] #2178479
10/19/16 11:39 AM
10/19/16 11:39 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Never seen mag catch on fire from water, but they sure do corrode fast from water and air. I had mag valve covers on my BAE hemis and we polished them every morning at the races to keep them looking good. After a week in the shop they looked like they were never polished ever.
I also had a mag dragster body built by Murf McKinny. I had to have it dipped/coated with some stuff called Dow7 to keep it from corroding and so it would hold paint. Mag=PIA My intake manifold and injector hat is mag also.
Re: Does NHRA allow magnesium wheels? [Re: Hemi_Joel] #2178498
10/19/16 12:07 PM
10/19/16 12:07 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Come on guys, magnesium doesn't spontaneously combust in water. The part people are referring to about the water is you can't use water to put a magnesium fire out. That won't work. You also can't use an "A", "B", or "C" fire extinguisher. All the fire extinguishers you see are "A", "B", "C" or a combination of those. All you can use on a magnesium fire is a "D" or dry sand. You probably don't know anybody that has a "D" fire extinguisher and dry sand seems to be hard to find when you really need it. Magnesium castings don't burn easily. Magnesium shavings will burn instantly. Magnesium dust is explosive.
2011 Drag Pak Challenger
Re: Does NHRA allow magnesium wheels? [Re: Stanton] #2178523
10/19/16 01:13 PM
10/19/16 01:13 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I should have qualified that with "under certain conditions" laugh2
The point I was trying to make is "if" the stuff ever takes fire it is pretty much impossible to put out. panic
Kevin
Re: Does NHRA allow magnesium wheels? [Re: Hemi_Joel] #2178703
10/19/16 06:35 PM
10/19/16 06:35 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Keep in mind that magnesium is regularly tig welded. So no, its doesn't catch fire easily.
Re: Does NHRA allow magnesium wheels? [Re: Stanton] #2178733
10/19/16 07:53 PM
10/19/16 07:53 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Only because the shielding gas is supposed to displace the oxygen from the weld. Add some O2 and you will get a very bright very hot white flame.
Kevin
Re: Does NHRA allow magnesium wheels? [Re: Monte_Smith] #2178763
10/19/16 08:54 PM
10/19/16 08:54 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Love me some Bogarts!!
My '63 330 will eventually get a set.
'63 Dodge 330
11.19 @ 121 mph
Re: Does NHRA allow magnesium wheels? [Re: Twostick] #2178818
10/19/16 10:34 PM
10/19/16 10:34 PM
State of Corruption
camdog440 Offline
camdog440  Offline
State of Corruption
Originally Posted By Twostick
A Mg fire is notoriously hard to put out,
Can you even put one out?
If water is used on a magnesium fire,the magnesium burns SO HOT it breaks down the water molecule and uses the oxygen for more fuel to the fire while also putting off flammable hydrogen.
The metals that DO spontaneously combust in water are lithium, sodium, potassium, etc... one column over on the periodic table from Mg.
The examples used in putting out Mg fires in my hazchem class were VW bugs and buses, which were prone to being on fire on the side of the road, and had magnesium engine blocks.
Re: Does NHRA allow magnesium wheels? [Re: camdog440] #2178949
10/20/16 01:51 AM
10/20/16 01:51 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
https://en.wikipedia.org/wiki/Water_splitting
Thermal decomposition of water
Thermal decomposition, also called thermolysis, is defined as a chemical reaction whereby a chemical substance breaks up into at least two chemical substances when heated. At elevated temperatures water molecules split into their atomic components hydrogen and oxygen. For example, at 2200 °C about three percent of all H2O molecules are dissociated into various combinations of hydrogen and oxygen atoms, mostly H, H2, O, O2, and OH. Other reaction products like H2O2 or HO2 remain minor. At the very high temperature of 3000 °C more than half of the water molecules are decomposed, but at ambient temperatures only one molecule in 100 trillion dissociates by the effect of heat.
https://en.wikipedia.org/wiki/Magnesium
Flammability of Magnesium
Magnesium is highly flammable, especially when powdered or shaved into thin strips, though it is difficult to ignite in mass or bulk. Flame temperatures of magnesium and magnesium alloys can reach 3,100 °C (3,370 K; 5,610 °F),[9] although flame height above the burning metal is usually less than 300 mm (12 in).[10] Once ignited, such fires are difficult to extinguish, with combustion continuing in nitrogen (forming magnesium nitride), carbon dioxide (forming magnesium oxide and carbon), and water (forming magnesium oxide and hydrogen). This property was used in incendiary weapons during the firebombing of cities in World War II, where the only practical civil defense was to smother a burning flare under dry sand to exclude atmosphere from the combustion.
