Dual cooling fans for e body #2177396
10/18/16 12:24 AM
10/18/16 12:24 AM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Let's hear about and see your dual electric fan set up on your E body!!!!
Re: Dual cooling fans for e body [Re: ccdave] #2177517
10/18/16 08:02 AM
10/18/16 08:02 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Standard Summit dual fans with a Be cool rad....
Re: Dual cooling fans for e body [Re: ccdave] #2178346
10/19/16 01:42 AM
10/19/16 01:42 AM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Looks good👍
Re: Dual cooling fans for e body [Re: ccdave] #2178395
10/19/16 05:51 AM
10/19/16 05:51 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
ccdave I have dual Ford fans in my 71 Barracuda, great but now the charging system needs an upgrade, they suck some power.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Dual cooling fans for e body [Re: ccdave] #2178397
10/19/16 05:52 AM
10/19/16 05:52 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
1971 Barracuda
Re: Dual cooling fans for e body [Re: ccdave] #2178434
10/19/16 10:01 AM
10/19/16 10:01 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The late model Challenger stuff is easy to adapt.
Doug
Re: Dual cooling fans for e body [Re: ozymaxwedge] #2178598
10/19/16 02:49 PM
10/19/16 02:49 PM
Southington Ct.
turbobitt Online content
turbobitt  Online Content
Southington Ct.
Not only do they suck power but they will burn the factory wiring running through the bulkhead into the fuse box regardless of how the fans are wired. All the charging current still runs through that wiring. The bulkhead connections are the most susceptible to fail.
AG.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Dual cooling fans for e body [Re: ccdave] #2178636
10/19/16 03:26 PM
10/19/16 03:26 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I was running the dual Spal fans with a Spal controller. The are some serious fans that need dedicated electrical circuits with dual relays.
I never had an issue with cooling even on the hottest days with A/C on, but am switching back to the new Hayden stubby clutch, metal fan and stock shroud. If you have room, its hard to beat.
They are still on the car, but are going up for sale very soon.
Re: Dual cooling fans for e body [Re: jbc426] #2179654
10/21/16 11:45 AM
10/21/16 11:45 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
That's what I've learned also, it makes life much easier to just run a mechanical fan setup, although I know it can slow the car down almost 2 tenths in the quarter. I ran the HHR fan on my race cars with a Meziere electric water pump but now that I just street drive mostly I run a cheap plastic flex fan and a really good custom shroud and it never ever runs hot, and no charging problems.
The electric setups are great for cooling between rounds, can't do that with a mechanical setup. I'd like to try a 55gpm remote-mounted electric water pump and HHR fan someday, along with a good alternator of course.
