340 piston to valve clearance question #217475
02/08/09 01:11 AM
02/08/09 01:11 AM
Or
mo-dart Offline OP
mo-dart  Offline OP
Or
I have a 73 340 with trw flat top 30 over pistons with untouched valve releafs. I picked up some brodix heads with a 63cc chamber 2.08 valves, 1.5 roller rockers and a used ultra dyne 570 lift solid cam Im wondering if anybody knows if those 2.08 will hit those 10.5 trw pistons
340 piston to valve
single choice
help
0%, 0 Votes
help
0%, 0 Votes
No Votes Yet
Voting on this poll ends: 02/08/09 12:10 AM
Re: 340 piston to valve clearance question [Re: mo-dart] #217476
02/08/09 01:25 AM
02/08/09 01:25 AM
Or
mo-dart Offline OP
mo-dart  Offline OP
Or
sorry im new to this form layout
Re: 340 piston to valve clearance question [Re: mo-dart] #217477
02/08/09 07:28 AM
02/08/09 07:28 AM
How deep are the valve reliefs on those pistons & how far are you in the hole
Re: 340 piston to valve clearance question [Re: RapidRobert] #217478
02/08/09 01:07 PM
02/08/09 01:07 PM
Or
mo-dart Offline OP
mo-dart  Offline OP
Or
we'll I'm not sure. The block is standard deck height though, as far as piston in the whole is concerned. I'll have to measure that relief. Do you know what it should be to clear.
Re: 340 piston to valve clearance question [Re: mo-dart] #217479
02/08/09 01:31 PM
02/08/09 01:31 PM
No I don't know exactly & I dont think those(stock) valve reliefs are very deep so I'm wondering how far they are in the hole.
