cam degreeing question #2173093
10/12/16 07:32 PM
10/12/16 07:32 PM
Warren, MI
Jerry Offline OP
Jerry  Offline OP
Warren, MI
I've got a 440 I put together years ago. the engine ran. I never thought it ran well. 74 block .030 over, stock crank 3.75 stroke. diamond racing pistons 10.5:1 compression. pistons are .005 in the hole without gaskets. running edelbrok rpm heads with 84cc chambers.
the cam is a mopar .557 lift 296 duration solid lifter cam. here is the issue, I went to degree the cam, got the timing wheel setup on TDC with a stop in the spark plug hole.
now when I measure the cam timing I seem to be 11 degrees off. I measured the cam at .050 lift. I have an adjustable timing chain set. but that only goes +/-8 degrees and I seem to be 11 degrees off. now i'm saying i'm 11 degrees off because i'm going by the intake opening point. should I measure the entire lobe profile and find the center? sorry a little new to this but being that far off has me worried i'm doing something completely wrong.
btw the engine only had 120 psi cranking compression when it was list fired. leads me to believe the cam is actually 11 degrees retarded, as advanced should bring the cranking compression up, and 120 psi sounds awfully low for this engine.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: cam degreeing question [Re: Jerry] #2173101
10/12/16 07:38 PM
10/12/16 07:38 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Must be retarded 11,I think 11* is 1 tooth on the crank gear but I could be wrong.
Re: cam degreeing question [Re: Clanton] #2173125
10/12/16 08:30 PM
10/12/16 08:30 PM
gregsdart Offline
gregsdart  Offline
Yep. Check the dots, it is probably out one tooth, retarded.
Re: cam degreeing question [Re: Clanton] #2173201
10/12/16 10:30 PM
10/12/16 10:30 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
1 tooth is 12 degrees. Close enough to show that it is more than likely off a tooth. But don't trust Clanton. He sniffs race gas and can't use a timing light (Read your other post haha )
[image][/image]
Re: cam degreeing question [Re: sgcuda] #2173215
10/12/16 10:49 PM
10/12/16 10:49 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
LOL Thanks for making me laugh.
Re: cam degreeing question [Re: Jerry] #2173216
10/12/16 10:50 PM
10/12/16 10:50 PM
Warren, MI
Jerry Offline OP
Jerry  Offline OP
Warren, MI
I will check in the morning about the tooth being off, but from memory i'm sure they were installed dot to dot.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: cam degreeing question [Re: Jerry] #2173234
10/12/16 11:11 PM
10/12/16 11:11 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
A tooth is 14deg on a double roller set up.
Absolutely don't go by only one timing event.
Check the intake and exhaust open/close points, then determine the installed c/l vs the desired c/l.
I have come across timing sets that had a dot on the wrong tooth 3 times..... So I never assume dot to dot is going to put the cam where it should be.
If you're using a 3 way set, between the +/- 8deg, and a bushing kit, you'll be able to get it within 1 deg.
Or, if it's way off and you don't want to deal with the bushings you can get a 9 way set or a Cloyes hex-a-just.
Re: cam degreeing question [Re: fast68plymouth] #2173279
10/12/16 11:50 PM
10/12/16 11:50 PM
birdtracker Offline
birdtracker  Offline
I thought I was the only one to ever do this. I messed my cam timing up and still don't have good compression. Even after putting it back to where it suppose to be my compression is low. I took the heads off to check for bent valves and everything was good. My thought is the rings never sealed. I plan on reringing it this winter. Good luck with your engine. Birdtracker
Re: cam degreeing question [Re: Jerry] #2173295
10/13/16 12:17 AM
10/13/16 12:17 AM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Originally Posted By Jerry
I've got a 440 I put together years ago. the engine ran. ...
You need to find the actual intake lobe centerline by finding the crank angle of two points equally down from max lift on either side. Then you need to somehow average the two angles.
Re: cam degreeing question [Re: Jerry] #2173350
10/13/16 02:04 AM
10/13/16 02:04 AM
I would first check the opening and closing at .050 lifter rise on both the intake an exhaust lifters, if you haven't done both yet, and then move the cam gear one tooth towards the passenger side of the block with the dots aligned to start with like it is now and then recheck the cam timing at .050 lifter rise on both lobes up twocents I would then degree the cam so I ended up with 3 to 6 degrees advanced on the intake lobe up
As already said one tooth on most double roller timing sets is between 11 and 14 degrees depending on the degree wheel and the cam timer whistling grin
Let us know what you find and do, changing cam timing 10 to 13 degrees retarded on the cam timing to straight up or advanced will turn a slug into a hero up scope
Re: cam degreeing question [Re: birdtracker] #2173388
10/13/16 05:13 AM
10/13/16 05:13 AM
here's a good read on breakin. "breakin secrets" at www.mototuneusa.com scroll down till you get to it. OP as said I would find intake lobe CL (highest point on the lobe peak) which'll be the number of degrees that number is away from piston TDC, IE 106 degrees. Holler how it turns out
Re: cam degreeing question [Re: Jerry] #2173581
10/13/16 01:26 PM
10/13/16 01:26 PM
So. Burlington, Vt.
So. Burlington, Vt.
Fwiw, I'd shoot for a 106-108 intake c/l.
If you had to move the cam several degrees to get it there, then I'd recheck the v/p clearance(unless when you checked it during the original build it had tons to spare).
Then before I buttoned everything back up I'd check the cranking compression again.
Re: cam degreeing question [Re: Jerry] #2173587
10/13/16 01:38 PM
10/13/16 01:38 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Try this to double check yourself when installing a chain or degreeing a cam. Rotate engine to TDC, make sure it is true TDC, on the exhaust stroke, this is the overlap period. Your exhaust valve will be closing and your intake will be opening. If the cam is installed heads up the lifters will be the same height out of their bores on both lifters. If the cam is advanced the intake lifter will be slightly higher, if retarded the exhaust will be higher. I use a small pocket ruler to sit on the lifters to visually see which one is higher or lower.
Re: cam degreeing question [Re: Jerry] #2173601
10/13/16 01:55 PM
10/13/16 01:55 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Jerry , you measuring off the lifter itself?
Re: cam degreeing question [Re: Jerry] #2173625
10/13/16 02:20 PM
10/13/16 02:20 PM
Warren, MI
Jerry Offline OP
Jerry  Offline OP
Warren, MI
I took the lash out of the system and was measuring at the valve retainer. I have 1.6:1 comp rockers on there. and was measuring .080 inches at the spring retainer.
right now the cam gear being marked a tooth off is making a lot of sense. hopefully i'll have time before the end of the day to get it rechecked.
I was going to swap a .528 cam in its place because this one was a dog down low. maybe if I get the cam timing sorted out, I wont have to.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: cam degreeing question [Re: Jerry] #2173678
10/13/16 03:18 PM
10/13/16 03:18 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
You will be redoing the ign timing and that will help also maybe.Noone has said it yet but it is the cam gear that is off 1 tooth not the crank like I said.
Re: cam degreeing question [Re: Jerry] #2173685
10/13/16 03:27 PM
10/13/16 03:27 PM
Minn
SportF Offline
SportF  Offline
Minn
Just to clarify this is going right for you, you say you have the piston stop in. That is used to zero the dial, then taken out, right?
Re: cam degreeing question [Re: Jerry] #2173710
10/13/16 03:56 PM
10/13/16 03:56 PM
Warren, MI
Jerry Offline OP
Jerry  Offline OP
Warren, MI
yes I took the stop out after I zeroed the pointer at TDC
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: cam degreeing question [Re: Jerry] #2173720
10/13/16 04:06 PM
10/13/16 04:06 PM
dogdays Offline
dogdays  Offline
For a symmetrical lobe one finds 0.050 opening point and closing point and takes the average of the two to get the centerline of the lobe. Asymmetrical lobes are a little different and I am not sure how to go about that. Possibly find the opening and closing points at 0.300" lift?
Then I'd do the same thing for an exhaust lobe to find the LSA. It should agree closely with the published LSA.
R.
Re: cam degreeing question [Re: Jerry] #2173722
10/13/16 04:11 PM
10/13/16 04:11 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
this is what Hughes says for degreeing a camshaft that is asymmetrical
http://www.hughesengines.com/Upload/productInstructions/camshaft_instructions_Mar_2016.pdf
edit: i did a little reading after this one ^ and it looks like lunati says to degree based off of the intake lobe opening vs. what the cam card says. ie. if the card says intake opens at 8* before and it opens 10* before then it's 2* advanced.
comp says to add the degrees from intake open and close and divide by two...
