Re: BB Oil Pumps
[Re: 408strokerdart]
#2175621
10/16/16 01:02 AM
10/16/16 01:02 AM
Posts: 19,543 Las Vegas
Al_Alguire
Las Vegas
Now we just need Charlie to start making them again..
Re: BB Oil Pumps
[Re: hemi-itis]
#2175934
10/16/16 12:02 PM
10/16/16 12:02 PM
Posts: 10,088 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Run a filter in the line right out of the pan ,got the idea from al (Hemitis)an inexpensive earls from summit They call it a pre filter,but it's a screen and the canister unscrews for inspection. I have one on both pick up lines. Jimi Vignogna instructed me to install a pair after a lifter failure and the entire oiling system got contaminated. I put one of those filters on my motor after a disastrous encounter with a failed rocker needle bearing. I am concerned about a restriction on the intake side, but if it will hold good oil pressure before the oil is up to temp, it must not be causing any problems? I was surprised the filter only has a flat screen in it, when there is plenty of room for a cone style that could double the screen area.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: BB Oil Pumps
#2176121
10/16/16 04:19 PM
10/16/16 04:19 PM
Posts: 12,593 Great Neck,LI,new york
hemi-itis
Greg,that's why call it a pre filter.Screen is tight enough to keep the chunks out so the pump doesn't jam breaking the drive. I looked at the other oil filter Jomar,,,,,,looks good, just doesn't say what the flow capacity is What about the the pump that Ray Barton uses??
Re: BB Oil Pumps
[Re: dthemi]
#2177067
10/17/16 05:37 PM
10/17/16 05:37 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
This is a dailey on one of my predator motors. Very similar to CW's in being spur, like a chevy, not chrysler gear rotor. He offers these in 3 different rotor lengths too. Is this a dry sump pump? Reason I'm asking is when I went on Bailey's website, I saw no oil pumps for wet sumps. Am I missing something here. I like the look of this pump and want to remove my Milodon oil system for something new.
Re: BB Oil Pumps
#2178320
10/19/16 01:17 AM
10/19/16 01:17 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I think it was mentioned that they were helical cut gears. Much more efficient if so. Sort of like the difference between a screw blower and a rotor blower.
Re: BB Oil Pumps
#2179755
10/21/16 02:47 PM
10/21/16 02:47 PM
Al_Alguire
Las Vegas
I got mine through an AH racer via a very well known engine shop that said they had "modified" it for a the customer. I do know they gears had a twist similar to the billet BBC pumps out there. Also it was much "smaller/thinner" than the KB pump it replaced. But those are fairly massive pumps. I had pics of it but cannot find them. Beginning to think they were on my phone that is gone.
Re: BB Oil Pumps
[Re: Al_Alguire]
#2180110
10/22/16 01:39 AM
10/22/16 01:39 AM
Posts: 6,163 Melbourne , Australia
LA360
The Gerotor design from what I was told, cavitates less than the gear type. But my memory isn't what it used to be.
The Westcott pump were a lot thinner than most available. But I would expect that from a Super Stock pump. The Barton pumps were too from memory. It's something I have always wanted to do some testing with, but on a small block
Alan Jones
