Re: SB Pistons
[Re: Lil Wedge]
#217190
02/07/09 09:18 PM
02/07/09 09:18 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
KB offers off the shelf stroker pistons for small blocks, either flat top or dished.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
Re: SB Pistons
[Re: Lil Wedge]
#217192
02/07/09 09:35 PM
02/07/09 09:35 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Dan, PM me or shoot me an email. I may be able to help your cause. I could not PM you. Thanks Todd compwedgeracing@aol.com
RIP Monte Smith
Re: SB Pistons
[Re: MR_P_BODY]
#217193
02/07/09 09:35 PM
02/07/09 09:35 PM
Posts: 316 Ohio
Lil Wedge
Ohio
Strictly race, 3000 lb Dart,currenly running Ross 12.5 with a 360 block, same heads, same cam. Just wondering aboutusing Flat top in new short block. 65 cc heads
Re: SB Pistons
[Re: Lil Wedge]
#217194
02/07/09 10:16 PM
02/07/09 10:16 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
I'm in the process of building a street/strip 408, the pistons are Diamond with a 20cc dish. with my 55cc heads the compression ratio is going to be 10.97-1, with flat tops it would've been 13.27-1.
If I calculated it correctly, flat tops with 5cc valve reliefs would yield about 11.8-1 in you're motor.
