Re: Molnar rods [Re: AndyF] #2174903
10/14/16 10:57 PM
10/14/16 10:57 PM
New York
polyspheric Offline
polyspheric  Offline
New York
horsepower has nothing to do with it. It is a function of piston/pin/ring weight and RPM
X2, reciprocating weight X RPM^2 (with a tiny adjustment for rod thrust angle) determines rod breakage.
Boffin Emeritus
Re: Molnar rods [Re: polyspheric] #2175199
10/15/16 12:41 PM
10/15/16 12:41 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Could you go through a calculation of this for us?
Re: Molnar rods [Re: AndyF] #2175278
10/15/16 02:41 PM
10/15/16 02:41 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Originally Posted By AndyF
Wait until you see the pistons for this engine. JE is designing a Mopar big block piston based off the LS design. The sides are moved in so the pin is shorter than normal. Should be really lightweight.
A modern design piston for our antique motors shock panic beer That's almost a unthinkable as a modern combustion chamber or a cam not designed 50+ years ago.
Re: Molnar rods [Re: 340Cuda] #2175303
10/15/16 03:33 PM
10/15/16 03:33 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Don't encourage him...
'63 Dodge 330
11.19 @ 121 mph
Re: Molnar rods [Re: GY3] #2175436
10/15/16 08:19 PM
10/15/16 08:19 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
iagree
Re: Molnar rods [Re: max_maniac] #2177074
10/17/16 05:49 PM
10/17/16 05:49 PM
dogdays Offline
dogdays  Offline
Actually there is a spreadsheet that has the program built into it to calculate acceleration and velocity of the piston for any stroke, rod length and rpm. I have it on my computer, don't know how to attach it, maybe I'll figure it out.
R.
Note in the spreadsheet the max acceleration numbers are always at the top, where velocity = zero. These numbers have units of ft/sec^2. To convert to Gs we divide by 32.2.
60,085 / 32.2 = 1,866 Gs. At that point a 500 gram piston is exerting an outward pull of 933kg or 2,055 lb.
rodratio (version 1).zip (20 downloads)
