what torsion bars for 1966 Satilite
#2169679
10/07/16 03:36 PM
10/07/16 03:36 PM
Posts: 635 mississippi
bentwheel43
mississippi
Hi, I need to buy torsion bars, .960 or .920
Section 8 Racing We are nuts about racing.
Re: what torsion bars for 1966 Satilite
[Re: bentwheel43]
#2169693
10/07/16 03:57 PM
10/07/16 03:57 PM
bentwheel43
mississippi
The car is going to need rear spring too so maybe you can help on the setup.
[Re: Clanton]
#2169698
10/07/16 04:07 PM
10/07/16 04:07 PM
bentwheel43
mississippi
446", 509 cam, B&M3000 stall, Ross racing pistons,M1 intake, 850 Holley, full race headers. It runs 11.72@115. The car is 3790# 4.10 gears
[Re: bentwheel43]
#2169701
10/07/16 04:10 PM
10/07/16 04:10 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
My vote for a bracket car would be to use at max a 318 t-bar.
Cal-tracs out back. I ran the XHD springs with mine, but the mono leaf is preferred.
The 509 cam can use way more than 3000 stall.
At that combo/weight, in a race car, I'd be looking at a 9.5 piece with around 4500 flash stall.
[Re: fast68plymouth]
#2169707
10/07/16 04:18 PM
10/07/16 04:18 PM
bentwheel43
mississippi
So would 318 bars be .920.
[Re: bentwheel43]
#2169708
10/07/16 04:23 PM
10/07/16 04:23 PM
fast68plymouth
So. Burlington, Vt.
No, the .920 bars were like what came in a GTX.
I don't recall the diameter of the std v8 bar..... I think it was either .860 or .880.
I have a set somewhere I can measure.
[Re: bentwheel43]
#2169710
10/07/16 04:30 PM
10/07/16 04:30 PM
Posts: 4,073 Mo.
racerx
Mo.
[Re: bentwheel43]
#2169720
10/07/16 04:38 PM
10/07/16 04:38 PM
Thumperdart
State of confusion
I ran the .810 bars w/my small block but the BB didn't care for em so I scored some .830-.840 bars from a 340 car and still run em w/good results..........
[Re: bentwheel43]
#2169801
10/07/16 07:34 PM
10/07/16 07:34 PM
fast68plymouth
So. Burlington, Vt.
I just checked to original bars out of my 383 68 Satellite...... They're .880.
I've had 6 cylinder bars in the car for about 30 years..... IIRC those are .840.
[Re: bentwheel43]
#2170227
10/08/16 12:47 PM
10/08/16 12:47 PM
bentwheel43
mississippi
My whole problem is before I got the car someone put a bar off of a Newport on the driver side. It tries to go all over the place going down the track, it so hard the drive at the big end.
[Re: bentwheel43]
#2170285
10/08/16 01:52 PM
10/08/16 01:52 PM
fast68plymouth
So. Burlington, Vt.
Std v8 .880 bars should be really easy to find since they came in most of the b bodies built.
[Re: Jeremiah]
#2170288
10/08/16 01:56 PM
10/08/16 01:56 PM
bentwheel43
mississippi
[quote=Jeremiah]Can measure the difference in bar diameter from side to side. I have an old set of circle track bars that are 1.20 and 1.25 and I always wondered if you would notice the difference. [/quote I was there when it happened, we were getting some tranny work when he put it on the ground it broke. The man told my friend he had a 68' Newport in the back so he put it on.
[Re: bentwheel43]
#2170290
10/08/16 02:03 PM
10/08/16 02:03 PM
fast68plymouth
So. Burlington, Vt.
Just measure the diameter of both sides then you'll know what you have.
[Re: bentwheel43]
#2170298
10/08/16 02:12 PM
10/08/16 02:12 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I just measured mine in my big block Duster yesterday, they seem to measure about 8.70-8.80 using a cheap digital caliper. I measured them because I was wondering if I need something bigger or if mine are simply wore out. I had to really crank the adjuster bolts tight to get the ride height I needed and something in the front of my car is starting to creak and groan alot when turning or hitting bumps in the road, seems like it might be my torsion bars since everything else looks good and new up front.
