Re: Change in valve lash and performance
[Re: 69CHARGERMD]
#2169972
10/07/16 11:14 PM
10/07/16 11:14 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Too many variables. Who knows it may go slower or faster but more than likely there will not be any difference.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: 69CHARGERMD]
#2170125
10/08/16 09:23 AM
10/08/16 09:23 AM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
Be careful it might slow down!
68 Barracuda Formula S 340
[Re: 69CHARGERMD]
#2170127
10/08/16 09:42 AM
10/08/16 09:42 AM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
Thanks guys. The correct lash was .020 and unbeknownst to be I had it set at .025. I will see what it does at the "correct" setting for now. Didn't want any uncessary wear if the lash was too loose. Will see if it picks up or slows down. Thanks guys. Case of beer to Prosport if it picks up a 1/2 second. Lol. Thanks Bob.
[Re: 69CHARGERMD]
#2170134
10/08/16 10:23 AM
10/08/16 10:23 AM
Bad340fish
Tulsa OK
If it slows down 1/2 second Prosport has to send you a case of beer lol.
Good luck!
[Re: 69CHARGERMD]
#2170497
10/08/16 07:17 PM
10/08/16 07:17 PM
69CHARGERMD
KENTUCKY
Car picked up all around. Was running 6.42s last week similar air. 6.39 off the trailer. 6.40 second run. 60' seems a bit better. ππ
[Re: Cab_Burge]
#2170533
10/08/16 08:41 PM
10/08/16 08:41 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I still don't understand why cam grinders specify such wide lash specs. I set mine at .012 so it's nice and quiet and it doesn't beat up the rockers and valves. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2170583
10/08/16 09:56 PM
10/08/16 09:56 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I still don't understand why cam grinders specify such wide lash specs. I set mine at .012 so it's nice and quiet and it doesn't beat up the rockers and valves. Gus I have seen lash go away when the engine cools down and hang the valves open when too tight. Not a lot, just enough to not allow the engine to start.
[image][/image]
[Re: 69CHARGERMD]
#2170625
10/08/16 11:16 PM
10/08/16 11:16 PM
ozymaxwedge
Australia
Well there you go,,, maybe I should put a little more time into my lash.
How do you guys go setting lash HOT ? Are you getting the temp right up, pulling plugs, covers, finding TDC firing and then starting the process ? I have always followed the Mopar chart, tdc set 1in 8out rotate 90deg ect. Buy the time you do all this it is half cold ???????
[Re: 69CHARGERMD]
#2170671
10/09/16 12:05 AM
10/09/16 12:05 AM
ozymaxwedge
Australia
Thanks Greg and old_racer .
[Re: lockjaw-express]
#2170677
10/09/16 12:14 AM
10/09/16 12:14 AM
Posts: 4,457 Washington
madscientist
Washington
Greg All,
what would you set cold at with Aluminum block and Aluminum heads with a roller cam?
Mark Set it .010-.012 cold and check it hot. If it's still loose, tighten the cold lash to make up the difference. I've set some all aluminum stuff as tight as .004 cold.
#2170680
10/09/16 12:17 AM
10/09/16 12:17 AM
Posts: 373 sandwich IL
sublimehemi
sandwich IL
Mine grows .017 edelbrock hemi heads and world block so if lash Is .024 I set .007...some people here set at zero lash as it will get to .017 hot...be carful as to always warm up before you rev.
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
