Re: Eagle head swap?
[Re: RTSE4ME]
#2158671
09/21/16 12:08 PM
09/21/16 12:08 PM
Triple Threat
Renton Washington
Are there any issues in swapping heads? PV clearance? Depends on the cam, the early stuff can't take much lift or duration Seems most use thicker gaskets to keep CR down but I am not concerned about compression. What head gasket would I use? Can I just use a Fel Pro replacement for an 05 5.7? any 5.7 gasket should work fine
