Is there a place to buy backing plate bolts for C-bodies? #2169220
10/06/16 08:53 PM
10/06/16 08:53 PM
Rust Land--CNY
TheCrystalShip Offline OP
Rust Land--CNY
I need a couple of bolts for my '66 New Yorker, one of the big ones with the cotter pin hole where the front backing plate bolts onto the ball joint and one of the smaller ones where it bolts onto the steering knuckle. Is there any place that sells these exact parts, or am I going to have to hit the junkyard? Thanks, Mark
Re: Is there a place to buy backing plate bolts for C-bodies? [Re: TheCrystalShip] #2169595
10/07/16 01:49 PM
10/07/16 01:49 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
You might try checking with Doctor Diff . . . Cass is known for his suspension and rear end parts . . . he may have what you need. . . .
Re: Is there a place to buy backing plate bolts for C-bodies? [Re: TheCrystalShip] #2169630
10/07/16 02:32 PM
10/07/16 02:32 PM
AndyF Offline
AndyF  Offline
AMK has a wide selection of OEM style bolts.
Re: Is there a place to buy backing plate bolts for C-bodies? [Re: TheCrystalShip] #2169821
10/07/16 08:08 PM
10/07/16 08:08 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I should have several used ones if you get desperate.
