Paint removale #2168495
10/05/16 05:46 PM
10/05/16 05:46 PM
71ragtop Offline OP
71ragtop  Offline OP
What is a good method of removing spray paint from a e-body interior door panel?
Re: Paint removale [Re: 71ragtop] #2168498
10/05/16 05:49 PM
10/05/16 05:49 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Lacquer thinner. Believe it or not, it won't hurt the panel. I wouldn't soak the panel in it, but I've used a lacquer thinner soaked rag before, and it works great.
Re: Paint removale [Re: 71ragtop] #2168527
10/05/16 06:18 PM
10/05/16 06:18 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I've used DOT 3 brake fluid. Spray some on with an old windex bottle, set it sit in the sun(keep it wet don't let it dry) then hit it with the pressure washer.
Re: Paint removale [Re: DaytonaTurbo] #2168707
10/05/16 11:21 PM
10/05/16 11:21 PM
Maryland
MoparMike1974 Offline
Maryland
A light soda blast may work.
Re: Paint removale [Re: 71ragtop] #2168714
10/05/16 11:25 PM
10/05/16 11:25 PM
Georgia
magiccuda Offline
magiccuda  Offline
Georgia
Ive had success using a light buffing compound.
