Any tips on replacing starter in my 70 HEMI Superbird #2168493
10/05/16 05:37 PM
10/05/16 05:37 PM
BRIDGEWATER, CT.
WINGNUT Offline OP
WINGNUT  Offline OP
BRIDGEWATER, CT.
Does the exhaust manifold have to be removed to get at the starter bolts and cable connections? The heat shield is in the way of getting to the top bolt. Any help would be appreciated.
Re: Any tips on replacing starter in my 70 HEMI Superbird [Re: WINGNUT] #2168536
10/05/16 06:28 PM
10/05/16 06:28 PM
Olympia, Washington
tallzag Offline
tallzag  Offline
Olympia, Washington
You can do it without removing the manifold but it is a giant pita, not a fun job. Used to haze new mechanics by making that the first job they did here at the shop, took one guy 8 hours lol. I usually attach the cables first then install.
Rocket Restorations
Re: Any tips on replacing starter in my 70 HEMI Superbird [Re: WINGNUT] #2168583
10/05/16 07:59 PM
10/05/16 07:59 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
I used to install a new starter every summer in my old '71 Hemi Charger, & never removed the manifold. The heat shield was a bit of a pain, finally after 2 years I just left the heat shield off. Didn't seem to make much difference.
