Re: How much can I build a motor with HP exhaust manifolds? [Re: 375inStroke] #2170776
10/09/16 09:34 AM
10/09/16 09:34 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Have you looked into big block A body headers?
Re: How much can I build a motor with HP exhaust manifolds? [Re: 375inStroke] #2170938
10/09/16 02:37 PM
10/09/16 02:37 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Originally Posted By 375inStroke
This car is a 1964 Dodge 880. I can't figure out what to call this body. It's not a C-Body, and it's not a Forward Look body, but it shares much with that earlier style engineering. I have not found anybody that has gotten a set of headers that will fit this type of car. The steering box is right against the firewall. The driver's side manifold is a center exit, like a truck. I think I can get B-Body HP manifolds to fit, but if anyone knows if long tube headers will fit, let me know. I've even seen people have problems with shorty headers in this style of chassis, but I'm open to suggestions.
What about hugger headers or is that what you refer to as shorty headers?
http://www.protuninglab.com/hds-moparbb-v8.html
Re: How much can I build a motor with HP exhaust manifolds? [Re: B5 Bee] #2170955
10/09/16 03:14 PM
10/09/16 03:14 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
That is kind of an oddball chassis.
Don't take that wrong.
I love the 880's.
The predecessor to the C-body.
Kinda heavy aint it?
I would be looking at building torque instead of H.P
Logs would not be a concern of mine.
I have mechanical Aptitude.
I can screw up anything.
Re: How much can I build a motor with HP exhaust manifolds? [Re: BSB67] #2172255
10/11/16 04:28 PM
10/11/16 04:28 PM
Seattle, WA
3
375inStroke Offline OP
Special needs person
3
Seattle, WA
If I knew longtubes would fit, I'd get them, but I don't think any for the popular bodies will work. The drag link, pitman, idler, and steering box are forward, and the torsion bars are further outboard on my Charger. The drag link and steering box are further back on the 880, and the torsions are further in. Shorties aren't for me. The HP manifolds have 1-3/4" area, and people are getting 500HP out of them. That's fine with me. Build for torque, but if anyone knows of headers that would fit, let me know.
These are TTI C-Body headers, followed by the 880. They look great, but my torsions would run right through where the tubes are, along with the pitman and idler, I think.
Re: How much can I build a motor with HP exhaust manifolds? [Re: 375inStroke] #2172262
10/11/16 04:39 PM
10/11/16 04:39 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The 880 is the same as the 300 in 64, chassis wise anyway.
Hedman claims these fit the 880. part number 78030
http://www.hedman.com/site/?d=119&dt=108
Don't be the exception.
Re: How much can I build a motor with HP exhaust manifolds? [Re: 375inStroke] #2172418
10/11/16 08:34 PM
10/11/16 08:34 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Could you use Max Wedge exhaust manifolds? Seems like they would work in that chassis, and flow decent, too.
Re: How much can I build a motor with HP exhaust manifolds? [Re: 375inStroke] #2174713
10/14/16 06:16 PM
10/14/16 06:16 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
ceramic coating the inside and outside of the manifold seems to be better bang for the buck than say extrude honing, keeps a big source of heat out of the engine compartment.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
