Page 3 of 5 1 2 3 4 5
Re: Do you fill your oil filters before installing? [Re: 6PakBee] #216804
02/08/09 10:20 AM
02/08/09 10:20 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Such a debate over something that only takes a couple of added seconds to do and doesn't cost anything. It isn't like it is doing something at great time loss, is difficult, or high cost. Any time that you can decrease the amount of time it takes for oil pressure to build it is added time to engine life. You spend a lot of money for a engine or engine build why not spend nothing to add a little lifetime to that engine. I have seen a lot of $$$ spent on things that will do less. Whether you feel it helps or not it sure isn't going to hurt.
Re: Do you fill your oil filters before installing? [Re: MoparforLife] #216805
02/08/09 11:19 AM
02/08/09 11:19 AM
Clarksville, Tennessee
monoptn Offline
mopar addict
monoptn  Offline
mopar addict
I won't debate the merits of filling vs not filling. But something did just strike me as funny. A meticulous mopar guy like me (and most of us here), carefully changing his oil, then filling the filter. Then, after carefully warming up the motor, dropping the hammer, laying a couple of black marks, and burning through the gears at near the redline.
Re: Do you fill your oil filters before installing? [Re: monoptn] #216806
02/08/09 01:30 PM
02/08/09 01:30 PM
Lost in the ozone again
stubbs300 Offline
Vacation
stubbs300  Offline
Vacation
We all have our opinions on this subject and some are more pigheaded about the yea's or nay's of prefilling it or not. I say, "A ounce of prevention is worth a pound of cure!" I have been doing it for years and I have noticed that in some cars, knocking as well as the pressure comes up quicker with pre-filling the filter first.
The way to prevent oil from spilling out is to fill the filter first and let it sit while you drain the pan. You will notice that the oil has been soaked into the filter. I have even gone as far as adding more to the filter to ensure it's full. To each there own.
Hey, you do what you do, and I do what I do!
Re: Do you fill your oil filters before installing? [Re: stubbs300 ] #216807
02/08/09 01:58 PM
02/08/09 01:58 PM
Upper Midwest
Upper Midwest
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Do you fill your oil filters before installing? [Re: MoparforLife] #216808
02/08/09 02:54 PM
02/08/09 02:54 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
Right on Little Brother. He does what he has to do and I do what I have to do. He is the Baby after all...Gotta Love him....
Re: Do you fill your oil filters before installing? [Re: CR8CRSHR] #216809
02/08/09 05:43 PM
02/08/09 05:43 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
I only fill the ones that are upright---oil and fuel.
Re: Do you fill your oil filters before installing? [Re: Michael] #216810
02/08/09 06:31 PM
02/08/09 06:31 PM
michigan
tonycpe Offline
tonycpe  Offline
michigan
So that's why a slant six sounds like an old type writer.
Old Fogey Racing Ltd.
Re: Do you fill your oil filters before installing? [Re: tonycpe] #216811
02/08/09 06:54 PM
02/08/09 06:54 PM
this is the last time I am going to open this thread. Now where is my preoiling shaft
Re: Do you fill your oil filters before installing? [Re: RapidRobert] #216812
02/08/09 07:08 PM
02/08/09 07:08 PM
Kirkland, Washington
Pacnorthcuda Offline
And as the poll states...three out four of us do it. Notice that not one person has offered up a why not reason other than the chance of spillage, and coming from someone who doesn't do it, how would they know how NOT to spill?
Re: Do you fill your oil filters before installing? [Re: MoparforLife] #216813
02/08/09 07:20 PM
02/08/09 07:20 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
X2
Re: Do you fill your oil filters before installing? [Re: Pacnorthcuda] #216814
02/08/09 07:21 PM
02/08/09 07:21 PM
JohnRR Offline
JohnRR  Offline
why beat the subject to death ? you are NOT going to change the mind of those that have their mind made up on the subject .
Re: Do you fill your oil filters before installing? [Re: JohnRR] #216815
02/08/09 07:25 PM
02/08/09 07:25 PM
Not out to change anyones mind, just find it interesting. Kind of a sharing of experiences/practices/ideas. Oh wait thats Moparts!
I am surprised this thread has continued so long, and yea I am part of the reason--so are you John! Enjoy
Re: Do you fill your oil filters before installing? [Re: RapidRobert] #216816
02/08/09 07:33 PM
02/08/09 07:33 PM
Newfoundland Canada
Mopar1 Offline
Mopar1  Offline
Newfoundland Canada
If you go through the trouble of changing the oil and filter, why would you take a chance on pushing unfiltered oil through your engine? Filling the filter may bring the oil pressure up a little quicker but, the first shot of oil is not filtered. Just because the new oil is in a new jug, it's not a guarrentee the oil is perfectly clean.
Re: Do you fill your oil filters before installing? [Re: MoparforLife] #216817
02/08/09 07:37 PM
02/08/09 07:37 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
Well, here`s a little tidbit for y`all right out of the FSM for my truck:
(7) Using a new pressure relief valve gasket,
install the relief valve plug. Tighten the plug to 20
N·m (15 ft. lbs.) torque.
(8) Install oil filter that has been filled with oil.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: Do you fill your oil filters before installing? [Re: gamagoat6x6] #216818
02/08/09 08:00 PM
02/08/09 08:00 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Is that not from a pump repair section? I believe they want you to do it that way so the crank driven pump does not lose its prime. What does the book state in the maintence section on filter change??
Re: Do you fill your oil filters before installing? [Re: 6PakBee] #216819
02/08/09 08:16 PM
02/08/09 08:16 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I never did prefill an oil filter. I suppose it's a good idea, I just never bothered. No reason not to, no reason to either, I don't think any engine has ever been harmed by it. If the engine was actually losing critical oil pressure during a dry start-up I think we'd hear something, be it lifters bleeding down or whatnot. I watched the oil pressure gauge on mine after an oil change and the extra time it took to start building oil pressure(compared to normal) was almost nothing.
When I had my turbo Daytona,they told me point blank I'd better prefill it by cranking the engine over with the coil wire grounded. They claimed they had actually replaced some turbos and had seen premature turbo failures due to oil changes when people started them up with dry filters.
I have to LOL at that. At idle speed the turbine on the turbo is not even spinning, or if it is, it's barely just slightly moving. So unless you change your oil, start the engine up and immediately mash the pedal to full boost, I don't see how you could have a problem. Even then oil would get there so quick you could never do any damage.
Re: Do you fill your oil filters before installing? [Re: DaytonaTurbo] #216820
02/08/09 08:25 PM
02/08/09 08:25 PM
US of A
A38s! Offline
A38s!  Offline
US of A
I had an old 93 VW VR6 with the open element cannister filter. Loved it. Was super easy to prefill. Cap was almost 6 qts full. Got me in the habit to do with everything I can.
WANTED: Your 71-78 Late B-body sedan parts! Police or Civilian.
Re: Do you fill your oil filters before installing? [Re: A38s!] #216821
02/08/09 08:36 PM
02/08/09 08:36 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I always fill my oil filters prior to installing them. Even on my F150 I6 where the filter is mounted horizontally. I can at least get it half full without spilling a drop.
Re: Do you fill your oil filters before installing? [Re: bigD] #216822
02/08/09 08:41 PM
02/08/09 08:41 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
FWIW, some filters have a standpipe for use in "upside down" installations, the Baldwin B253 has the same mounting dimensions as the typical Mopar and has a standpipe to help prevent drainback.
Re: Do you fill your oil filters before installing? [Re: RapidRobert] #216823
02/08/09 08:52 PM
02/08/09 08:52 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Put me down as a "no i dont", but i crank a few seconds before starting
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
