Re: Do you fill your oil filters before installing?
[Re: CHRGR69]
#216784
02/07/09 09:28 PM
02/07/09 09:28 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Try filling a stock Slant 6 Oil Filter prior to install....Aint gonna happen without a big mess
Try it with a 383/440.
On the 440 I can easily fill the filter to about 1/2 way and still spin it on without spilling a drop. Done it MANY times.
Whats the point, other the the obvious? These engines are almost bullet proof. You think they filled the filters back in the day? Think not.
Oh but we did when possible in the dealership where I worked. saw a few engines (mostly BBlocks) air lock with a empty filter.
[Re: dave571]
#216785
02/07/09 09:30 PM
02/07/09 09:30 PM
Posts: 3,380 KY USA
mopargem
KY USA
Nonsence and I dont believe the poll is real world correct, most engines it would be a pain in the rear.
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F6 M6W 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
[Re: mopargem]
#216786
02/07/09 09:35 PM
02/07/09 09:35 PM
Posts: 13,618 md
mopars4ever
md
[Re: mopargem]
#216787
02/07/09 09:43 PM
02/07/09 09:43 PM
Posts: 21,847 Kirkland, Washington
Pacnorthcuda
Read the responses. I have not installed a DRY filter in probably 15 years. Even on an inverted filter you can at least wet the media. Is it anal? Yea probably, but there is no downside, costs nothing, takes seconds, so why not. I do agree that in many cases the 'time-to-pressure' difference may be negligable, but again--why not?
On horizontal mounted filters(Mopar big blocks being one) I can easily fill the filter half full without spilling a drop during install.
[Re: 440newport]
#216792
02/07/09 10:44 PM
02/07/09 10:44 PM
Posts: 4,761 Florida
BDW
It may not make a huge difference but I feel better doing it that way.
I don't fill, chance of making a mess is greater than possible engine damage. A gazillion quickie lubes can't be wrong.
But, if it makes you feel good, go for it.
[Re: Pacnorthcuda]
#216794
02/07/09 10:52 PM
02/07/09 10:52 PM
Posts: 3,358 Berwyn, IL
challenger70
Berwyn, IL
.........Is it anal? Yea probably, but there is no downside, costs nothing, takes seconds, so why not. I do agree that in many cases the 'time-to-pressure' difference may be negligable, but again--why not?
[Re: Pacnorthcuda]
#216796
02/08/09 12:55 AM
02/08/09 12:55 AM
Posts: 10,030 Wisconsin
Aero426
Wisconsin
I fill my 440 filters as much as I can before putting it on. Again, pretty much a no brainer.
[Re: hemigod426]
#216797
02/08/09 01:10 AM
02/08/09 01:10 AM
Aero426
Wisconsin
never fill mine ever on hemi or 440, spin on new filter, pull coil wire and turn key. all filled and primed, put back coil wire all done and fire
Not a bad idea.
[Re: GwaiiEagle]
#216799
02/08/09 02:53 AM
02/08/09 02:53 AM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
I do. But the deal with taking the coil wire off, I tried that it, it gets oil pressure faster buy just starting it than turning it over until the light/live gauge goes off without the coil wire hooked up. Besides that, have you ever tried that with a blaster two coil. It will jump fire out of the end of the coil and ark on the side of the coil. I couldn't believe it had that much ump! The first time I did it I left the coil wire on it and it was jumping from the end of the coil wire to the firewall, then I took it off from the coil and it did what I said above. So then next time I did it I just unhooked the MSD box.
Moparlee
[Re: mopargem]
#216803
02/08/09 10:05 AM
02/08/09 10:05 AM
Posts: 10,768 North Dakota
6PakBee
North Dakota
For years my local dealership has been swearing that if you have a turbo engine you better prefill before starting. When I had my turbo Daytona,they told me point blank I'd better prefill it by cranking the engine over with the coil wire grounded. They claimed they had actually replaced some turbos and had seen premature turbo failures due to oil changes when people started them up with dry filters. When the CTD's came along, they added these engines to the list. Bottom line, I prefill the filter on my CTD and did on the Daytona until I finally wore it out. The other engines I really don't see a need and never have prefilled.
