Front Fender Exhaust Downpipe Layout HELP #2167148
10/03/16 05:07 PM
10/03/16 05:07 PM
michigan
turbo toad Offline OP
michigan
Im in the process of the build where I'm mocking the downpipes up and trying to figure out where I'm going to be able to exit the piping. I have the turbos mounted inside the fenders and I have started to run the pipe up and over the front tire and have a straight shot out the side of the fender with a 90° bend but its going to land on a fender fin which well be a pita cutting in the fender with a 5 1/4 holesaw.
I may be able to put a 45° bend in which will kick the pipe down some and get it lower then the flare in the fender.
Where I need help is some ideas on laying out the thru holes so both sides are coming out in the same spot. I cant afford to make a mistake so I need some insight before i decided to pull the trigger.
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: Front Fender Exhaust Downpipe Layout HELP [Re: turbo toad] #2167173
10/03/16 05:53 PM
10/03/16 05:53 PM
Plymouth, MI
Blusmbl Online content
Blusmbl  Online Content
Plymouth, MI
Is there any room to have it turn 90* immediately and dump it in front of the front tire on both sides, behind the headlights?
Re: Front Fender Exhaust Downpipe Layout HELP [Re: turbo toad] #2167179
10/03/16 05:58 PM
10/03/16 05:58 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Out the top get my vote.
Mopar to the bone!!!
Re: Front Fender Exhaust Downpipe Layout HELP [Re: turbo toad] #2167184
10/03/16 06:08 PM
10/03/16 06:08 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Seems like 5 inch is huge for twins, I'd neck it down if the turbine wheel is not 5 inch
Re: Front Fender Exhaust Downpipe Layout HELP [Re: turbo toad] #2167234
10/03/16 07:16 PM
10/03/16 07:16 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Get yourself a couple of 2x8 chunks of wood. Hole saw one of them first, put the other on the back side, C clamp them in a fashion that doesn't bend the fender all up. The side that is already sawed will act as a real nice guide. I do this when I need to make oval holes and it works really well. I will also serve as an easy way to make sure the hole ends up where you want it. You can use this method at an angle also if you need to.
And yeah.... out the top would be my choice also!
Re: Front Fender Exhaust Downpipe Layout HELP [Re: Blusmbl] #2167249
10/03/16 07:31 PM
10/03/16 07:31 PM
michigan
michigan
Turbos are where the headlight buckets use to be and theres not enuff room between the tires and the turbos
Re: Front Fender Exhaust Downpipe Layout HELP [Re: FastmOp] #2167251
10/03/16 07:40 PM
10/03/16 07:40 PM
michigan
michigan
I could neck it down but I'm trying to keep back pressure to a minimal
Re: Front Fender Exhaust Downpipe Layout HELP [Re: TRENDZ] #2167257
10/03/16 07:53 PM
10/03/16 07:53 PM
michigan
michigan
This is a great idea TRENDZ thanks. Out the top of the fender isnt out of the question but the natural curves of the fender made it pretty easy to get it over the front wheel.
Re: Front Fender Exhaust Downpipe Layout HELP [Re: turbo toad] #2167261
10/03/16 08:05 PM
10/03/16 08:05 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
It might be the angle but it looks like the tire will hit it on compression
Re: Front Fender Exhaust Downpipe Layout HELP [Re: turbo toad] #2167265
10/03/16 08:12 PM
10/03/16 08:12 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
For what it's worth, mine neck's down to less then 4" as it passes the torsion bar. So far with that tied to another 8 feet of exhaust and muffler it's supported 850+hp on single exhaust.
So as long as you're not trying to make more then 1700hp (850hp x 2) you've got plenty of room in the backpressure department to downsize.
I suggest getting the hole in the fender where it belongs, and finding a way to connect the dots, even if that means reduced diameter or pie cutting something to get the bend tighter.
Don't give up!!!
Re: Front Fender Exhaust Downpipe Layout HELP [Re: The Shadow] #2167270
10/03/16 08:32 PM
10/03/16 08:32 PM
michigan
michigan
Probably the angle theres 26.5 inch tires on the car right now and when the suspension is compressed theres about a 1 inch clearance I dont have my front runners on it yet which are about 24 inches which should give me another inch of clearance.
Re: Front Fender Exhaust Downpipe Layout HELP [Re: dizuster] #2167276
10/03/16 08:43 PM
10/03/16 08:43 PM
michigan
michigan
[quote=dizuster]For what it's worth, mine neck's down to less then 4" as it passes the torsion bar. So far with that tied to another 8 feet of exhaust and muffler it's supported 850+hp on single exhaust.
Don't give up.
No worries about giving up Im closer now then ever before and im getting excited my car is final starting to look like a turbo car once again. up I'm just nervous about popping a couple big azz holes in the sides of my fenders sawzall
Re: Front Fender Exhaust Downpipe Layout HELP [Re: turbo toad] #2167314
10/03/16 09:21 PM
10/03/16 09:21 PM
michigan
michigan
Heres a pic of what Im working with this is the passenger side. Both side are pretty close to Identical
Re: Front Fender Exhaust Downpipe Layout HELP [Re: turbo toad] #2167365
10/03/16 10:29 PM
10/03/16 10:29 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
As long as the exhaust pipe is the same size as the turbine wheel your good.
I think the holes look better farther back and lower on the fender.
But mine exits the hood lol
Re: Front Fender Exhaust Downpipe Layout HELP [Re: turbo toad] #2167397
10/03/16 11:13 PM
10/03/16 11:13 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Do you get any flame out of the pipe on a hard run?
Re: Front Fender Exhaust Downpipe Layout HELP [Re: TRENDZ] #2167406
10/03/16 11:28 PM
10/03/16 11:28 PM
michigan
michigan
Ive seen some cars throw flames when they come off the 2 step....or when guys play games staging there rides at the line
Or when you cook the top of a piston weld
Re: Front Fender Exhaust Downpipe Layout HELP [Re: turbo toad] #2167446
10/04/16 12:27 AM
10/04/16 12:27 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Out the top, plus it will help keep the nose down lol.
Re: Front Fender Exhaust Downpipe Layout HELP [Re: turbo toad] #2167450
10/04/16 12:33 AM
10/04/16 12:33 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I don't get any flame yet. But I leave at low boost. My best 60 foot has been at 7 psi. 1.15 sixty
Re: Front Fender Exhaust Downpipe Layout HELP [Re: turbo toad] #2167509
10/04/16 03:11 AM
10/04/16 03:11 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Why does it need to come out the fender? You are already running it over tire, just come down the back of wheelwell and let it dump straight down or turn it out a little right at bottom of fender.
Like this. Also this car has twin Pro Mod 88s and runs 4 teens. You don't need 5" exhaust
Re: Front Fender Exhaust Downpipe Layout HELP [Re: turbo toad] #2167511
10/04/16 03:19 AM
10/04/16 03:19 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
No front clip pic to see size and how it's run
