440-1 heads w572 -13 pistons ? #2166186
10/01/16 11:28 PM
10/01/16 11:28 PM
canada
fast414 Offline OP
fast414  Offline OP
canada
Want to put 440-1 heads on a short block with 572-13 pistons.....will the valve notches work ?
Re: 440-1 heads w572 -13 pistons ? [Re: fast414] #2166464
10/02/16 02:43 PM
10/02/16 02:43 PM
canada
fast414 Offline OP
fast414  Offline OP
canada
Nobody ???????
Re: 440-1 heads w572 -13 pistons ? [Re: fast414] #2166496
10/02/16 03:25 PM
10/02/16 03:25 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I never try'd. Use clay and check the radial clearance
Re: 440-1 heads w572 -13 pistons ? [Re: fast414] #2166518
10/02/16 04:17 PM
10/02/16 04:17 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I would have thought so, I went the other way from -1's to 572-13's and the valves clipped radially but the depth wasn't an issue (used the same cam). I'd still check it though.
Re: 440-1 heads w572 -13 pistons ? [Re: fast414] #2166698
10/02/16 09:52 PM
10/02/16 09:52 PM
canada
fast414 Offline OP
fast414  Offline OP
canada
Ok thanks guys I haven't purchase the short yet .i just wanted to make sure I didn't have to buy new pistons
Re: 440-1 heads w572 -13 pistons ? [Re: fast414] #2166728
10/02/16 10:44 PM
10/02/16 10:44 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Its easy enough for the right guy to fly-cut the pistons if needed. Tom Hemphill in PA fly-cut my 440-1 pistons so I could also run my B1 heads.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 440-1 heads w572 -13 pistons ? [Re: pittsburghracer] #2166765
10/02/16 11:44 PM
10/02/16 11:44 PM
K
KOS Offline
KOS  Offline
K
thats good to know ....i figured the same why couldnt you just cut new notches but i was told from a couple different mopar builders that i would need new pistons going from -1s to b1s......maybe pistons end up being thin?guess it depends on what you have for pistons to begin with.
Re: 440-1 heads w572 -13 pistons ? [Re: fast414] #2166805
10/03/16 12:46 AM
10/03/16 12:46 AM
ky
68roadrunner Offline
ky
works fine on my flat top pistons. i ordered -13 pistons then put my -1 heads on them
now i have the pistons if i want to change to the bigger head
hope this helps
Re: 440-1 heads w572 -13 pistons ? [Re: 68roadrunner] #2166875
10/03/16 03:25 AM
10/03/16 03:25 AM
Who makes and sells the 572-13 heads and what block and bore size will they work on? How well do they flow and what size valves are in them? help
Re: 440-1 heads w572 -13 pistons ? [Re: fast414] #2166879
10/03/16 04:03 AM
10/03/16 04:03 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Indy heads. Similar to a B1
Re: 440-1 heads w572 -13 pistons ? [Re: Cab_Burge] #2166933
10/03/16 11:10 AM
10/03/16 11:10 AM
K
KOS Offline
KOS  Offline
K
they dont flow much better than a -1 and need 4.5 bore....can have larger port volume than -1 when fully ported guess thats the advantage with a bigger cube motor.
Re: 440-1 heads w572 -13 pistons ? [Re: KOS] #2167232
10/03/16 07:14 PM
10/03/16 07:14 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
my 572-13,s flowed 410cfm, with a 335cc port......
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
