Restricting oil flow through pushrods from roller lifters? #2165569
10/01/16 01:01 AM
10/01/16 01:01 AM
gregsdart Offline OP
Well, I got the right lifters from Isky. They have two large feed holes. I have a .060 hole in each lifter bushing. The feed holes on the lifters are 90 degrees away from that hole, but oil flow to the pushrods is too much and oil pressure with hot oil is only max 50 psi at over 7,000 rpm at the stripe. So I need help figuring out how to restrict these lifters just enough to still feed the pushrods and keep the valve train alive, but not cause the loss of pressure. Can I block one of the two feed holes in the lifters? There is zero oil going through the spraybars now, I blocked them in an attempt to stop the pressure loss. That didn't do enough to help bring back the oil pressure.
Re: Restricting oil flow through pushrods from roller lifters? [Re: gregsdart] #2165574
10/01/16 01:14 AM
10/01/16 01:14 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Roll pins in the pushrods. I've tried 3 different methods. Epoxy in the lifter holes came loose. Brass tubing locktited in the pushrods came loose. This method is working perfect. They stay tight. I got this tip from a guy who said he's done it for years with no issue. Mine has 60psi@1500, 80 @2500. Ive already cut the relief valve spring in the pump to lower the pressure.
Doug
Re: Restricting oil flow through pushrods from roller lifters? [Re: gregsdart] #2165580
10/01/16 01:24 AM
10/01/16 01:24 AM
AndyF Offline
AndyF  Offline
You can get pushrods with internal restrictors
Re: Restricting oil flow through pushrods from roller lifters? [Re: gregsdart] #2165629
10/01/16 03:28 AM
10/01/16 03:28 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I'd love to see what the oil feed hole situation looks like in the new lifters.
Re: Restricting oil flow through pushrods from roller lifters? [Re: AndyF] #2165655
10/01/16 08:25 AM
10/01/16 08:25 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Roll pins are a hell of a lot cheaper
Doug
Re: Restricting oil flow through pushrods from roller lifters? [Re: fast68plymouth] #2165690
10/01/16 10:05 AM
10/01/16 10:05 AM
Dwayne, they look to be bigger than the ones in my Comp Cams lifters, plus there are two!
Re: Restricting oil flow through pushrods from roller lifters? [Re: gregsdart] #2165692
10/01/16 10:07 AM
10/01/16 10:07 AM
Doug, were you able to get roll pins the exact size of the pushrod holes? These are Manton pushrods. What size hole did it end up with?
Re: Restricting oil flow through pushrods from roller lifters? [Re: gregsdart] #2165787
10/01/16 11:54 AM
10/01/16 11:54 AM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
Call manton,send and have them replace the rocker tip of the pushrod to a "restrictor tip" I always have a .030" tip installed on every engine I put together... You only need enough oil up top to keep everything happy, to much oil will fill your vacuum tank and steal oil where its needed....
Re: Restricting oil flow through pushrods from roller lifters? [Re: gregsdart] #2165836
10/01/16 01:24 PM
10/01/16 01:24 PM
So. Burlington, Vt.
So. Burlington, Vt.
Greg, I understand what you're saying, but if/when you pull them out, I'd love a visual so I can see what combination isnt working. A pic of the feed hole in the bushing would be great too.
Re: Restricting oil flow through pushrods from roller lifters? [Re: gregsdart] #2165861
10/01/16 01:45 PM
10/01/16 01:45 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
[quote=gregsdart]Doug, were you able to get roll pins the exact size of the pushrod holes? These are Manton pushrods. What size hole did it end up with?
[/quot
My push rods were roughly .100". I used 3/32×1/4" long(aprox .058 restriction). They pressed nice and solid. They're in the bottom of the push rod. My therory was if they started move I'd catch it. When it was apart for inspection none had moved.
Doug
Re: Restricting oil flow through pushrods from roller lifters? [Re: gregsdart] #2166030
10/01/16 06:28 PM
10/01/16 06:28 PM
Winterpeg, Canada
hvyweight Offline
hvyweight  Offline
Winterpeg, Canada
I had the same issues with ISKY lifters. Easy fix drill and tap for a small brass plug. I experimented and found I only needed a .015 hole...the other side I pulled solid. Engine has been together for 8 years or so with a lot of 7800 rpm passes. I got the drills and brass from McMaster Carr.
Mike
Re: Restricting oil flow through pushrods from roller lifters? [Re: gregsdart] #2166148
10/01/16 10:13 PM
10/01/16 10:13 PM
Dwayne, will do if I pull them. It may be a. long time if the restrictors solve my problem. I plan on putting in roll pins like DVW suggested first. If that isn't enough then out they come.
Thanks for the idea HVYweight. Will keep that in mind.
Re: Restricting oil flow through pushrods from roller lifters? [Re: gregsdart] #2166154
10/01/16 10:25 PM
10/01/16 10:25 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My Mantons have a .063" hole in them.
Re: Restricting oil flow through pushrods from roller lifters? [Re: gregsdart] #2166163
10/01/16 10:40 PM
10/01/16 10:40 PM
Mine measure .087 in the 1/2 inch exhaust pushrods. I had to go to 7/16 on the intakes, I hope they are the same. Haven't checked on them yet.
Re: Restricting oil flow through pushrods from roller lifters? [Re: gregsdart] #2166167
10/01/16 10:48 PM
10/01/16 10:48 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Mine are .120" wall 11/32".
Re: Restricting oil flow through pushrods from roller lifters? [Re: boatracer572] #2166182
10/01/16 11:22 PM
10/01/16 11:22 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I love that pic!!!!
My smallblock stuff is ancient rum dum tech, so nothing to add.
