Restricting oil flow through pushrods from roller lifters?
#2165569
10/01/16 01:01 AM
10/01/16 01:01 AM
Posts: 9,997 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Well, I got the right lifters from Isky. They have two large feed holes. I have a .060 hole in each lifter bushing. The feed holes on the lifters are 90 degrees away from that hole, but oil flow to the pushrods is too much and oil pressure with hot oil is only max 50 psi at over 7,000 rpm at the stripe. So I need help figuring out how to restrict these lifters just enough to still feed the pushrods and keep the valve train alive, but not cause the loss of pressure. Can I block one of the two feed holes in the lifters? There is zero oil going through the spraybars now, I blocked them in an attempt to stop the pressure loss. That didn't do enough to help bring back the oil pressure.
Re: Restricting oil flow through pushrods from roller lifters?
[Re: gregsdart]
#2165629
10/01/16 03:28 AM
10/01/16 03:28 AM
Posts: 14,498 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I'd love to see what the oil feed hole situation looks like in the new lifters.
[Re: AndyF]
#2165655
10/01/16 08:25 AM
10/01/16 08:25 AM
Posts: 9,835 MI, usa
dvw
MI, usa
You can get pushrods with internal restrictors Roll pins are a hell of a lot cheaper Doug
[Re: fast68plymouth]
#2165690
10/01/16 10:05 AM
10/01/16 10:05 AM
gregsdart
I'd love to see what the oil feed hole situation looks like in the new lifters. Dwayne, they look to be bigger than the ones in my Comp Cams lifters, plus there are two!
[Re: gregsdart]
#2165836
10/01/16 01:24 PM
10/01/16 01:24 PM
fast68plymouth
So. Burlington, Vt.
Greg, I understand what you're saying, but if/when you pull them out, I'd love a visual so I can see what combination isnt working. A pic of the feed hole in the bushing would be great too.
[Re: gregsdart]
#2166148
10/01/16 10:13 PM
10/01/16 10:13 PM
gregsdart
Dwayne, will do if I pull them. It may be a. long time if the restrictors solve my problem. I plan on putting in roll pins like DVW suggested first. If that isn't enough then out they come. Thanks for the idea HVYweight. Will keep that in mind.
[Re: boatracer572]
#2166182
10/01/16 11:22 PM
10/01/16 11:22 PM
Posts: 5,989 Anoka County, MN
Leigh
Anoka County, MN
Call manton,send and have them replace the rocker tip of the pushrod to a "restrictor tip" I always have a .030" tip installed on every engine I put together... You only need enough oil up top to keep everything happy, to much oil will fill your vacuum tank and steal oil where its needed.... I love that pic!!!! My smallblock stuff is ancient rum dum tech, so nothing to add.
