Prognosticate dyno results... Updated with results
#216424
02/07/09 12:18 AM
02/07/09 12:18 AM
Posts: 3,616 Riverside, Ca
G_bob
Riverside, Ca
It was actually ran today, so we know what it made, but will give you a chance to guess anyway. This motor is going in my wife's 64 fury vert (if the body shop ever gets done with it). Will have a 727 and 8 3/4 with 3.23's behind it. Meant to be a nice cruiser. 413 block bored to 4.25", 3.75 stroke, 426 ci. 440 source heads worked over a bit by Brian (OU812/IMM). Flow numbers Lift Int Exh .200 150 113 .300 220 145 .400 270 174 .500 292 195 Indy SR 1.5 rockers Comp XE275HL Cam, .525/.525 lift, 231/237 @ .050, 110 ls, installed 4 degrees advanced Ross flat tops, zero deck, 9.6:1 cr Performer RPM manifold. First, guess what it made with a holley 770 street avenger, vacuum secondaries Then, what did a holley 950hp do for it? So what do you think it made for hp and tq? Rob, you don't get to play. BTW, Mrs. G-bob's already asking if she can run the car down the strip.
Re: Prognosticate dyno numbers for this combo...
[Re: G_bob]
#216426
02/07/09 12:29 AM
02/07/09 12:29 AM
Posts: 957 Heart of Ohio
4boxers4
Heart of Ohio
413 block bored to 4.25", 3.75 stroke, 426 ci. 440 source heads worked over a bit by Brian (IMM/OU812). Flow numbers Lift Int Exh .200 150 113 .300 220 145 .400 270 174 .500 292 195 Indy SR 1.5 rockers Comp XE275HL Cam, .525/.525 lift, 231/237 @ .050, 110 ls, installed 4 degrees advanced Ross flat tops, zero deck, 9.6:1 cr Performer RPM manifold.
i'll play...538hp
Persistance is omnipotent
Durability Engineer, Chair and Couch division...
[Re: Cab_Burge]
#216429
02/07/09 01:24 AM
02/07/09 01:24 AM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
436 horse and 505 tq with the vac sec...
455 horse and 529 tq with the 950...
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: Prognosticate dyno results for this combo...
[Re: Quicktree]
#216434
02/07/09 04:13 PM
02/07/09 04:13 PM
G_bob
Riverside, Ca
Well, here it is.... With the 770 carb, it made a best hp 459 at 5500 rpm and 485 tq at 4500 rpm. With the 950hp, it made 470 hp at 5500 and 505 tq at 4200 rpm. Here is a video of the last dyno pull. 426 dyno video Thanks Brian, Mrs G-bob loves it.
