Prognosticate dyno results... Updated with results #216424
02/07/09 12:18 AM
02/07/09 12:18 AM
Riverside, Ca
G_bob Offline OP
G_bob  Offline OP
Riverside, Ca
It was actually ran today, so we know what it made, but will give you a chance to guess anyway.
This motor is going in my wife's 64 fury vert (if the body shop ever gets done with it). Will have a 727 and 8 3/4 with 3.23's behind it. Meant to be a nice cruiser.
413 block bored to 4.25", 3.75 stroke, 426 ci.
440 source heads worked over a bit by Brian (OU812/IMM).
Flow numbers
Lift Int Exh
.200 150 113
.300 220 145
.400 270 174
.500 292 195
Indy SR 1.5 rockers
Comp XE275HL Cam, .525/.525 lift, 231/237 @ .050, 110 ls, installed 4 degrees advanced
Ross flat tops, zero deck, 9.6:1 cr
Performer RPM manifold.
First, guess what it made with a holley 770 street avenger, vacuum secondaries
Then, what did a holley 950hp do for it?
So what do you think it made for hp and tq?
Rob, you don't get to play.
BTW, Mrs. G-bob's already asking if she can run the car down the strip.
Re: Prognosticate dyno numbers for this combo... [Re: G_bob] #216425
02/07/09 12:27 AM
02/07/09 12:27 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I guess my guess wouldn't be valid...
It does sound and run nice!
Re: Prognosticate dyno numbers for this combo... [Re: G_bob] #216426
02/07/09 12:29 AM
02/07/09 12:29 AM
Heart of Ohio
4boxers4 Offline
4boxers4  Offline
Heart of Ohio
440 source heads worked over a bit by Brian (IMM/OU812).
Flow numbers
Lift Int Exh
.200 150 113
.300 220 145
.400 270 174
.500 292 195
Indy SR 1.5 rockers
i'll play...538hp
Persistance is omnipotent Durability Engineer, Chair and Couch division...
Re: Prognosticate dyno numbers for this combo... [Re: G_bob] #216427
02/07/09 12:49 AM
02/07/09 12:49 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
465 HP and 485# of torque. Small cam/comp and CI displacement. mike
73 Sport 440, 509 cam w/Eddys 3.91 and 28.1"/27.3 tire. Et. 60 ft. 1.435, 1/8th. 6.61 @ 101.80 mph. 1/4. 10.472 / 127.78 mph. 2950# race/with me,and pump gas.
Re: Prognosticate dyno numbers for this combo... [Re: G_bob] #216428
02/07/09 01:09 AM
02/07/09 01:09 AM
With the small carb around 435 hp and 450 ft lbs. With the big carb around 525 HP and 540 ft. lbs
Re: Prognosticate dyno numbers for this combo... [Re: Cab_Burge] #216429
02/07/09 01:24 AM
02/07/09 01:24 AM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
436 horse and 505 tq with the vac sec...
455 horse and 529 tq with the 950...
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: Prognosticate dyno numbers for this combo... [Re: Cab_Burge] #216430
02/07/09 01:26 AM
02/07/09 01:26 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
470hp/460lbs tq small carb and 485hp/475lbs tq big carb.
Keep old mopars alive.
Re: Prognosticate dyno numbers for this combo... [Re: 2boltmain] #216431
02/07/09 02:08 AM
02/07/09 02:08 AM
SoCal
Brian Hafliger Offline
SoCal
Someone is very close....
Brian Hafliger
Re: Prognosticate dyno results for this combo... [Re: G_bob] #216432
02/07/09 09:11 AM
02/07/09 09:11 AM
NC
440Jim Offline
440Jim  Offline
NC
Pure guess work...
480 with the small carb
492 with the 950 carb if you leaned it out (bet it was rich for that combo)
Re: Prognosticate dyno results for this combo... [Re: 440Jim] #216433
02/07/09 09:24 AM
02/07/09 09:24 AM
Q
Quicktree Offline
Quicktree  Offline
Q
i'll say 520hp 490 tq with the 950
Re: Prognosticate dyno results for this combo... [Re: Quicktree] #216434
02/07/09 04:13 PM
02/07/09 04:13 PM
Riverside, Ca
G_bob Offline OP
G_bob  Offline OP
Riverside, Ca
Well, here it is....
With the 770 carb, it made a best hp 459 at 5500 rpm and 485 tq at 4500 rpm.
With the 950hp, it made 470 hp at 5500 and 505 tq at 4200 rpm.
Here is a video of the last dyno pull.
426 dyno video
Thanks Brian, Mrs G-bob loves it.
Re: Prognosticate dyno results for this combo... [Re: G_bob] #216435
02/07/09 09:50 PM
02/07/09 09:50 PM
SoCal
SoCal
426 dyno video
Good to hear Glenn! Thank you!!
I will say that the 950 was actually jetted perfect for this engine, we had average 12.75:1 and it was in the low 13's at top end of the pull.
The 950HP carb was worth 20ft.lbs. of TQ!! Average HP gain with that carb was 15HP from 3000-5700rpm.
Average TQ gain was 20ft.lbs. from 3000-5700 rpm.
It idled down nice at 850rpm, nice chop to the idle and was clean and crisp even with the 770 Avenger carb.
Now it's time to move on to the other project....
Brian Hafliger
Re: Prognosticate dyno results for this combo... [Re: Brian Hafliger] #216436
02/07/09 10:02 PM
02/07/09 10:02 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Hey I see I was the one that was really close with my 465 HP and 485# ft.torque.
I am surprised that the 950 HP carb upped the torgue to 505# at a lessor 4200 RPM. Thats good news for that carb. what are your thoughts on that Brian. mike
Re: Prognosticate dyno results for this combo... [Re: Brian Hafliger] #216437
02/07/09 10:32 PM
02/07/09 10:32 PM
NC, USA
davenc Offline
davenc  Offline
NC, USA
Just curious....
Which spring was in the secondarys of the 770? What was the A/F like?
Thanks!
Re: Prognosticate dyno results for this combo... [Re: davenc] #216438
02/08/09 12:11 AM
02/08/09 12:11 AM
SoCal
SoCal
I believe the lightest spring was in that avenger carb. A/F averaged 12.25 with the avenger once the secondaries opened. It carried 1.7" of vacume before they opened!!
I think the vacume secondaries were coming in so late that changed peak TQ, cause there really is no other explanation that I can see for that happening.
It sounded much better with the 950 that's for sure!!!!
Re: Prognosticate dyno results for this combo... [Re: Brian Hafliger] #216439
02/08/09 02:37 AM
02/08/09 02:37 AM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
Good work Brian, really nice numbers for a big street car. Love to see the ricer that tries to run Mrs. G-bob from the greenlight.
