THANKS!Brian@IMM,ISKY
#2164184
09/29/16 08:39 AM
09/29/16 08:39 AM
Posts: 10,037 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Some of you may recall my problems with pushrods, and the fact that I found out I didn't have pushrod oiling in the new EZ roll X lifters I got from Isky. Brian from Indio Motor Machine called Isky about it, and the big problem was I had already run them, and hadn't spotted the lack of oil holes before assembly. After some discussion, Isky replaced them at no cost. That is a $1200+ set of lifters, and to say I am thankful is an understatement. Thanks again, Greg
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: THANKS!Brian@IMM,ISKY
[Re: gregsdart]
#2164308
09/29/16 12:53 PM
09/29/16 12:53 PM
Posts: 20,228 Park Forest, IL
slantzilla
Park Forest, IL
WOW! That is amazing service. Glad it worked out for you Greg.
