Re: Electrolytic Rust and Paint Removal [Re: kentj340] #2172013
10/11/16 10:56 AM
10/11/16 10:56 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I tried the molasses, now I'll empty the tank and try this way awile. Still need to do the fenders and hood over, molasses didn't work right, probably the mixture was off, but I don't like the orange scum that is hard to get off. I have a few of the ho train transformers (dc) that I'll be trying.
Re: Electrolytic Rust and Paint Removal [Re: kentj340] #2173005
10/12/16 04:39 PM
10/12/16 04:39 PM
Cut and Shoot, TX
kentj340 Online penguin-006 OP
kentj340  Online Penguin-006 OP
Cut and Shoot, TX
It should be mentioned that baked on acrylic enamel over 2 or 3 coats of primer is not as easy to get off with electrolysis as the interior paint on the dash frame and steering column. It's still a good way, just not as fast.
Since I want to use electrolysis on hood, fenders, trunk, and doors, I need a bigger pool. The 52" round hard plastic one was a good starter for about $17. Wal-Mart has bigger soft plastic inflatable rectangular ones for about $50 + an inflator for under $20.
https://www.walmart.com/ip/Intex-Wet-Set.../21950307#about
Re: Electrolytic Rust and Paint Removal [Re: kentj340] #2187215
11/01/16 04:04 AM
11/01/16 04:04 AM
Cut and Shoot, TX
Cut and Shoot, TX
Don't bother with the vinyl wading pool pictured above. It leaks down enough air in a half day to start spilling water.
