Re: INITIAL AV GAS IMPRESSION..............
[Re: Twostick]
#2161982
09/26/16 01:32 PM
09/26/16 01:32 PM
Posts: 1,030 ohio
67mprfan
ohio
Know how to make a small fortune in aviation? Probably the same formula as trucking. Start with a large one. Kevin Better yet build a race car LOL
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 67mprfan]
#2162047
09/26/16 02:40 PM
09/26/16 02:40 PM
Posts: 43,099 Bend,OR USA
Cab_Burge
[Re: rebel]
#2162105
09/26/16 04:02 PM
09/26/16 04:02 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
I run a special brew Helicopter AV gas. Its designed for Turbo Prop engines, has no Glycol as helicopters dont get high enough & you only get it from a tanker, heaps of lead & has a 108 rating. engine definately runs smoother on this brew than Ground Tank AV gas. Somebody is yanking your chain, or you are trying to yank someones. Aircraft fuels boil down to these choices Jet A, Jet A-1, Jet B and Avgas. Since the first 3 are kerosene based for turbine type engines, that means any piston driven engine runs Avgas. And there are no special "brews"
[Re: Thumperdart]
#2162107
09/26/16 04:07 PM
09/26/16 04:07 PM
Posts: 8,018 Tulsa OK
Bad340fish
Tulsa OK
Not sure if it matters that he isn't in the US or not.
68 Barracuda Formula S 340
[Re: 71birdJ68]
#2162156
09/26/16 05:27 PM
09/26/16 05:27 PM
Posts: 4,647 aotearoa
rebel
aotearoa
Boy, please don't advise other people when you don't know what you're talking about. Turbo props are jet engines and burn Jet A which is kerosine. No lead and the octane is around 30 or so. Certified piston helicopters use the same AV gas as airplanes if that is what their type certificate says they have to use, there maybe some with a STC to use car gas. sorry, i wrote from my phone & it did some auto correct, i had written turbo piston but it decided to write something else. this gas is not the same as std AV gas & it's brewed in the tanker & only used on select helicopters down here. it looks like AV gas, but the smell is slightly stronger. AV gas has a rating of 100, this is 108 & as stated before, has no glycol. you need to chill a bit dude.
[Re: rebel]
#2164437
09/29/16 03:43 PM
09/29/16 03:43 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Uhmmmm what fairy dust have you been smoking? Turbo props run a blend of Kerosene called Jet fuel, Avgas 100LL is 100 octane, it has a lot of lead in it, enough to get lead fouled plugs.... I run a special brew Helicopter AV gas. Its designed for Turbo Prop engines, has no Glycol as helicopters dont get high enough & you only get it from a tanker, heaps of lead & has a 108 rating. engine definately runs smoother on this brew than Ground Tank AV gas.
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Cab_Burge]
#2164439
09/29/16 03:44 PM
09/29/16 03:44 PM
astjp2
Utah and Alaska
Mogas is basically unleaded gasoline, same as what is in a car.
[Re: Thumperdart]
#2164486
09/29/16 04:50 PM
09/29/16 04:50 PM
Posts: 4,205 New York
polyspheric
New York
Add no oil into the fuel X2, lowers the octane, will knock at lower temperature and pressure limits.
Boffin Emeritus
[Re: astjp2]
#2164590
09/29/16 07:12 PM
09/29/16 07:12 PM
Cab_Burge
Mogas is basically unleaded gasoline, same as what is in a car. Thanks for the answer Are the envoirmentalists still trying to get the lead out of avaition 100 LL fuel?
[Re: Thumperdart]
#2188746
11/03/16 02:33 PM
11/03/16 02:33 PM
Challenger 1
Cincinnati, Ohio
I was talking with Dick Weinle the owner of Edgewater drag strip here in Cincinnati. He is a pilot and keeps planes down at his drag strip along with avgas. I am going to fly his plane here soon and am going to pay him for avgas. He tells me that 100LL avgas is rated differently than car race gas and that 100LL is like 112-113 auto race gas? I really have no idea to be honest, but he should know since he tells me he buys it 8000 gallons at a time and he has had it for many years at his drag strip. I believe he sells it to the racers for there race cars. Anyone ever heard of this difference in octane ratings?
[Re: Cab_Burge]
#2188799
11/03/16 03:46 PM
11/03/16 03:46 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I`m going back to "car" gas w/the VP-101 Unleaded since I've been using it since this motor was freshened 5+ years ago................
[Re: Thumperdart]
#2189272
11/04/16 10:13 AM
11/04/16 10:13 AM
Posts: 13,351 Marion, South Carolina [><]
an8sec70cuda
I have heard the 100LL is rated differently and is higher than 100 octane, but no one could tell me what it actually is.
FWIW...I have an old friend that ran a 468" BBC that was 13:1 w/ 2 stages of nitrous for YEARS on nothing but 100LL w/ no trouble.
[Re: Thumperdart]
#2189533
11/04/16 04:46 PM
11/04/16 04:46 PM
Posts: 5,160 Texas
dannysbee
Texas
I bought a new mod vp engine from Mercury Marine in the late 80's and 100ll was the recommended fuel. It was a high performance outboard engine.
Getting old just means you were smarter than some and luckier than others.
