Re: Motor alignment 72 duster [Re: WHITEDART] #2162533
09/27/16 01:25 AM
09/27/16 01:25 AM
CA.
RAY1969CARS Offline OP
CA.
Originally Posted By WHITEDART
Originally Posted By RAY1969CARS
[quote=WHITEDART]One key component is the engine limiter
limiter... ???? White dart
very important on a motor plate mid plate setup how to use a engine limiter.. mine is off the trans.. if I remember I will snap a few pictures tomorrow.. or maybe someone can post a picture of theirs.. you may already have a provision welded to the frame somewhere
Theses ??
Re: Motor alignment 72 duster [Re: RAY1969CARS] #2162534
09/27/16 01:29 AM
09/27/16 01:29 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Yes
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Motor alignment 72 duster [Re: WHITEDART] #2162536
09/27/16 01:33 AM
09/27/16 01:33 AM
CA.
CA.
Yes
If I'm using the transmission crossmember do I still need this ????
Re: Motor alignment 72 duster [Re: RAY1969CARS] #2162540
09/27/16 01:36 AM
09/27/16 01:36 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I would use a polyurethane trans mount. To help with some of the vibration and shock and at minimum a single limiter
Re: Motor alignment 72 duster [Re: WHITEDART] #2162545
09/27/16 01:45 AM
09/27/16 01:45 AM
CA.
CA.
Covered
Re: Motor alignment 72 duster [Re: RAY1969CARS] #2162664
09/27/16 10:13 AM
09/27/16 10:13 AM
MR_P_BODY Offline
MR_P_BODY  Offline
A engine limiter is a bar that takes out any fore
and aft movement on the engine/trans on the launch..
I have 2 on mine... they go to the motor mount ears
then to the chassis on a 45* angle... some run them
off the ears on the trans
wave
Re: Motor alignment 72 duster [Re: WHITEDART] #2164857
09/30/16 12:17 AM
09/30/16 12:17 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Here is how we did it it's sandwiches in between the trans and trans mount. And it goes back to the driveshaft Loop that we built.. you can use 2 if you want. But doing it this way is also working fine.. it's a heavy car that runs pretty good.. and had zero issues with motor staying in place
Re: Motor alignment 72 duster [Re: RAY1969CARS] #2164962
09/30/16 06:30 AM
09/30/16 06:30 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine at the trams.
Doug
