Re: INITIAL AV GAS IMPRESSION.............. [Re: Twostick] #2161982
09/26/16 01:32 PM
09/26/16 01:32 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Originally Posted By Twostick
Originally Posted By 71birdJ68
Know how to make a small fortune in aviation?
Probably the same formula as trucking. Start with a large one.
Kevin
Better yet build a race car LOL
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: INITIAL AV GAS IMPRESSION.............. [Re: 67mprfan] #2162047
09/26/16 02:40 PM
09/26/16 02:40 PM
I remember seeing a SS racer with a enclosed trailer back in the mid 1970s with a bumper sticker on the rear door that said "The only way to make a small fortune from drag racing is to start with a large fortune work I believe him now up whiney whistling Besides what is the price of fun shruggy
Re: INITIAL AV GAS IMPRESSION.............. [Re: rebel] #2162105
09/26/16 04:02 PM
09/26/16 04:02 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Originally Posted By rebel
I run a special brew Helicopter AV gas. Its designed for Turbo Prop engines, has no Glycol as helicopters dont get high enough & you only get it from a tanker, heaps of lead & has a 108 rating. engine definately runs smoother on this brew than Ground Tank AV gas.
Somebody is yanking your chain, or you are trying to yank someones. Aircraft fuels boil down to these choices Jet A, Jet A-1, Jet B and Avgas. Since the first 3 are kerosene based for turbine type engines, that means any piston driven engine runs Avgas. And there are no special "brews"
Re: INITIAL AV GAS IMPRESSION.............. [Re: Thumperdart] #2162107
09/26/16 04:07 PM
09/26/16 04:07 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Not sure if it matters that he isn't in the US or not.
68 Barracuda Formula S 340
Re: INITIAL AV GAS IMPRESSION.............. [Re: 71birdJ68] #2162156
09/26/16 05:27 PM
09/26/16 05:27 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Boy, please don't advise other people when you don't know what you're talking about. Turbo props are jet engines and burn Jet A which is kerosine. No lead and the octane is around 30 or so. Certified piston helicopters use the same AV gas as airplanes if that is what their type certificate says they have to use, there maybe some with a STC to use car gas.
sorry, i wrote from my phone & it did some auto correct, i had written turbo piston but it decided to write something else. this gas is not the same as std AV gas & it's brewed in the tanker & only used on select helicopters down here. it looks like AV gas, but the smell is slightly stronger. AV gas has a rating of 100, this is 108 & as stated before, has no glycol. you need to chill a bit dude.
Re: INITIAL AV GAS IMPRESSION.............. [Re: Thumperdart] #2162159
09/26/16 05:30 PM
09/26/16 05:30 PM
Minnesota, USA
minnesota guy Offline
Minnesota, USA
So av gas 100 is 108 octane for the street rating? I get it at my local airport down to 4.00 gallon!
Re: INITIAL AV GAS IMPRESSION.............. [Re: Monte_Smith] #2162207
09/26/16 06:23 PM
09/26/16 06:23 PM
tboomer Offline
tboomer  Offline
JP 8?? I think that's what my brother called it. He was a crew chief on a CH-47.
Re: INITIAL AV GAS IMPRESSION.............. [Re: tboomer] #2162218
09/26/16 06:29 PM
09/26/16 06:29 PM
People's Republic of Mass.
Belvedere2 Offline
Belvedere2  Offline
We used JP-5 off navy ships for our amtracs' turbo diesel.
Re: INITIAL AV GAS IMPRESSION.............. [Re: rebel] #2164437
09/29/16 03:43 PM
09/29/16 03:43 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Uhmmmm what fairy dust have you been smoking? Turbo props run a blend of Kerosene called Jet fuel, Avgas 100LL is 100 octane, it has a lot of lead in it, enough to get lead fouled plugs....
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: INITIAL AV GAS IMPRESSION.............. [Re: Cab_Burge] #2164439
09/29/16 03:44 PM
09/29/16 03:44 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Mogas is basically unleaded gasoline, same as what is in a car.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: INITIAL AV GAS IMPRESSION.............. [Re: Thumperdart] #2164486
09/29/16 04:50 PM
09/29/16 04:50 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Add no oil into the fuel
X2, lowers the octane, will knock at lower temperature and pressure limits.
Boffin Emeritus
Re: INITIAL AV GAS IMPRESSION.............. [Re: astjp2] #2164590
09/29/16 07:12 PM
09/29/16 07:12 PM
Thanks for the answer up
Are the envoirmentalists still trying to get the lead out of avaition 100 LL fuel?
Re: INITIAL AV GAS IMPRESSION.............. [Re: Thumperdart] #2188746
11/03/16 02:33 PM
11/03/16 02:33 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I was talking with Dick Weinle the owner of Edgewater drag strip here in Cincinnati. He is a pilot and keeps planes down at his drag strip along with avgas. I am going to fly his plane here soon and am going to pay him for avgas.
He tells me that 100LL avgas is rated differently than car race gas and that 100LL is like 112-113 auto race gas? I really have no idea to be honest, but he should know since he tells me he buys it 8000 gallons at a time and he has had it for many years at his drag strip. I believe he sells it to the racers for there race cars.
Anyone ever heard of this difference in octane ratings? shruggy
Re: INITIAL AV GAS IMPRESSION.............. [Re: Thumperdart] #2188759
11/03/16 02:49 PM
11/03/16 02:49 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I believe the old avgas formulation was rated at 100 octane lean/130 octane rich. 100LL I think has replaced that, having half the lead of the old 100/130. I don't know if that same octane range still applies to 100LL however 100LL is supposed to be the replacement for the old stuff. In the future as environmental regs tighten further, expect 100LL to go away and be replaced by an unleaded equivalent.
Also I think avgas is rated motor octane only, not the R+M/2 like auto gas.
Re: INITIAL AV GAS IMPRESSION.............. [Re: DaytonaTurbo] #2188789
11/03/16 03:36 PM
11/03/16 03:36 PM
The three different octane ratings I remember on aviation fuel back in the 1970s where 80/85,100/115 and 130/145. the low octane numbers where for when the motors was run at full rich and the higher number was at max power, maximum EGT readings, not lean and not rich scope Later on in the mid 1980s the 130/145 got replaced with 115/130 which ended up going away also whiney
Re: INITIAL AV GAS IMPRESSION.............. [Re: Cab_Burge] #2188799
11/03/16 03:46 PM
11/03/16 03:46 PM
State of confusion
Thumperdart Offline OP
State of confusion
I`m going back to "car" gas w/the VP-101 Unleaded since I've been using it since this motor was freshened 5+ years ago................
Re: INITIAL AV GAS IMPRESSION.............. [Re: Thumperdart] #2189272
11/04/16 10:13 AM
11/04/16 10:13 AM
an8sec70cuda Offline
I have heard the 100LL is rated differently and is higher than 100 octane, but no one could tell me what it actually is.
FWIW...I have an old friend that ran a 468" BBC that was 13:1 w/ 2 stages of nitrous for YEARS on nothing but 100LL w/ no trouble.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: INITIAL AV GAS IMPRESSION.............. [Re: an8sec70cuda] #2189385
11/04/16 12:57 PM
11/04/16 12:57 PM
K
KOS Offline
KOS  Offline
K
thats true.....i used to get a spec sheet and ive never seen it lower that 106.its 100 min usually btw 106-113.when it was a higher batch i would grab more of it wink
Re: INITIAL AV GAS IMPRESSION.............. [Re: Thumperdart] #2189533
11/04/16 04:46 PM
11/04/16 04:46 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
I bought a new mod vp engine from Mercury Marine in the late 80's and 100ll was the recommended fuel. It was a high performance outboard engine.
Getting old just means you were smarter than some and luckier than others.
