First passes...Help me spend my $. Gears or converter?
#2161430
09/25/16 03:51 PM
09/25/16 03:51 PM
Posts: 867 Bellevue, NE
Charger453
Bellevue, NE
The car is a 70 Charger, just under 3800# with me in the seat. Combo is:
499" low deck, 13:1 on e85 Ported -1 heads, flow 355/275 @.750 Porter spec'd solid roller 268/274, .785/.746 with the 1.7 Jesels. Cam has a 110 lobe separation, installed at 106.5 ICL. 4500 Indy intake with plenum mods and port matched. 1150 Dominator from Horsepower Innovations 2-2 1/8 TTI step headers, 3 1/2" exhaust dumped at the axle.
The current converter is a 9.5 PTC that was built for an old combo. Being in a hurry, I let a local shop take a crack at adjusting the stall speed. I requested 4800-4900 flash. It only goes to 4300.
I have a 3.55 rear gear with a 28x10.5 slick. The 727 trans does have a low gear set.
My first trip to the track just a couple weeks ago netted 3 passes that were all 6.52-6.54 @ 108.1-108.2 with 1.54-1.56 60's in decent summer air for here, 2500 DA. I love the streetability of the 3.55s, but what am I really giving up by not running a 3.91?
In your opinion will I see more gains getting the converter loosened up to around 5,000 by PTC or going to a 3.91 gear?
I'm actually pleased with the ET considering the current setup, but obviously I'm leaving a lot on the table judging by the slow 60', but good MPH.
Re: First passes...Help me spend my $. Gears or converter?
[Re: Charger453]
#2161443
09/25/16 04:11 PM
09/25/16 04:11 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The converter will help the most. The big question is just how much slip going to 5,000 stall will create. Call PTC and give them your specs and they can give you an idea of what to expect. The car definitely should respond to the higher stall, especially with the 3.55 gears.
[Re: Charger453]
#2161446
09/25/16 04:15 PM
09/25/16 04:15 PM
Posts: 43,251 Bend,OR USA
Cab_Burge
I've never raced or tested a car that is like yours, weight, C.I. and so on. I have tested 3.73,3.91,4.10 and finally 4.30 in my old 3450 lb Duster with a pump gas low deck 518 C.I. with both a 10 inch converter and then a 8 inch race T/A SS hemi converter. That car ran mid tens(10.49) at 127 MPH in the 1/4 mile with the ten inch converter, it ran low 10.30 at 127 MPH with the 8 inch converter The gears didn't make much differences in the 60 fts, 330,660 or 1/4 mph with the 10 inch converter, the 8 inch converter flat worked way better than the 10 inch did It was easier to drive in the pits and on the street and race at the track Make sure and buy a very good converter, don't cut corners on them I've heard really good things on this forum about Lenny at Ultimate converters, same thing on Lupo Dynamic converters, T/A, A-1 and several others Good luck, let us know what you do and the results please.
[Re: Charger453]
#2161454
09/25/16 04:25 PM
09/25/16 04:25 PM
Charger453
Bellevue, NE
You can definitely make a 9.5" flash to 5k. I had an only Dynamic that was 4,400 on my old 453 low deck. Once I added a Procharger, it went to 5,000. I sold that and my old 4.10 center section. A Procharger, 5,000 stall, 4.10s, a small tire, a marginal track, and a low gear set in the trans wasn't working well. I think a call to PTC is in order because I do wonder how that high of a stall would work with 3.55s. I'd really like to keep the gearing if I'm only going to see .10 or so in the 1/8. I literally drive the heck out of this thing compared to guys with similar cars. I think the low gear set I have in the trans has to make it seem like a 3.91 in first compared to having a stock ratio gear set. I'm guessing my 60' should be low 1.40s for the ET and that MPH should be good for 6.30s??? At least that's what I hope to see with a change.
[Re: Charger453]
#2161456
09/25/16 04:30 PM
09/25/16 04:30 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
On my street car I have a Lupo 9.5". It flashes to 4750 rpm on motor behind my mild 493 with 3.55's and a 28" tire, so it's possible. My combo is only ~400-450 rwhp. With ~100hp worth of giggle juice, it flashed to 5000 rpm.
Slippage at the stripe was ~9% last time I did the math, though.
I agree with Cab, huge gains won't happen with gears if you have a good converter.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: Charger453]
#2161463
09/25/16 04:40 PM
09/25/16 04:40 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
If you get a converter that's really dialed in for that combo it should me worth more than the gears...... But I don't think either is going to make a "big" difference.
Is it dead hooking now?
[Re: fast68plymouth]
#2161466
09/25/16 04:49 PM
09/25/16 04:49 PM
Charger453
Bellevue, NE
Is it dead hooking now? Yep, zero tire spin. I wish it was easy to post a video. This thing leaves LAZY. I'm really seeing if something can get me into the 6.30s. I told myself I'd be damn happy if I got 6.50s as is and it did.
[Re: Charger453]
#2161509
09/25/16 06:09 PM
09/25/16 06:09 PM
Thumperdart
State of confusion
I'm actually pleased with the ET considering the current setup, but obviously I'm leaving a lot on the table judging by the slow 60', but good MPH. Carb..............
[Re: Charger453]
#2161537
09/25/16 07:27 PM
09/25/16 07:27 PM
Posts: 595 Nashville, Tennessee
Tempest
You can definitely make a 9.5" flash to 5k. I had an only Dynamic that was 4,400 on my old 453 low deck. Once I added a Procharger, it went to 5,000. I sold that and my old 4.10 center section. A Procharger, 5,000 stall, 4.10s, a small tire, a marginal track, and a low gear set in the trans wasn't working well. I think a call to PTC is in order because I do wonder how that high of a stall would work with 3.55s. I'd really like to keep the gearing if I'm only going to see .10 or so in the 1/8. I literally drive the heck out of this thing compared to guys with similar cars. I think the low gear set I have in the trans has to make it seem like a 3.91 in first compared to having a stock ratio gear set. I'm guessing my 60' should be low 1.40s for the ET and that MPH should be good for 6.30s??? At least that's what I hope to see with a change. It went from 4,400 to 5,000 because of the Procharger. HP/TQ is going to change the stall speed significantly. So yes as posted above, a tighter converter will stall higher with more power. I put the same 8" behind two different motors, the stall speed was 1,000 RPM different.
[Re: Charger453]
#2161697
09/26/16 12:04 AM
09/26/16 12:04 AM
fast68plymouth
So. Burlington, Vt.
It feels lazy...... Cuz it is lazy. Big(ish) heads, big(ish) intake, big(ish) cam, big carb, big headers,.....heavy car, tall gears, not enough stall. It's just not a culmination of parts that's going to hit hard.
While the 60' is a little weak, the 6.5x seems pretty strong to me for the "overall" combo.
Basically, to fully exploit that engine package you'd have to make it where you'd lose most of the "streetability" aspect of the car.
[Re: Charger453]
#2161731
09/26/16 12:58 AM
09/26/16 12:58 AM
Posts: 21 Chicagoland Area
TheCragarKing
Chicagoland Area
I got a 9" for sale that stalled @ about 4800 behind what I had... Betcha it'll stall around 5000 behind your application. PM me if interested.
Last of the V8's
~67 Coronet 440
[Re: Charger453]
#2161759
09/26/16 01:46 AM
09/26/16 01:46 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
No way I would touch the converter at this point, especially if you intend to add nitrous anytime soon.
If you really need more stall, get a smaller converter. When you loosen those 9.5-10 inch units up that much you get a heat building pig that feels sloppy on the street.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: Charger453]
#2161900
09/26/16 11:36 AM
09/26/16 11:36 AM
Posts: 13,377 Marion, South Carolina [><]
an8sec70cuda
If you plan on running N/A, you need a better converter.
If you plan on spraying it...leave it alone.
