Help line out 4 speed shifter (71 charger bench seat)
#2158685
09/21/16 12:34 PM
09/21/16 12:34 PM
Posts: 8,846 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
All came off a 71 bench seat 4 speed car. Pistol grip levers rods and dog bone. Bought many moons ago Car is painted now so it's going back togeather Put the z bar in just a bit ago Was told I had the levers on up side down. So I took them off the rods and out the 2 long flat levers on top (1-2. 3-4) short one on reverse Now the rods will all need sorted out Wich was should the reverse flat lever be pointing so as tranny is not in reverse? Right now I can't get them to move by hand
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: Help line out 4 speed shifter (71 charger bench seat)
[Re: toplescuda]
#2158898
09/21/16 06:11 PM
09/21/16 06:11 PM
Posts: 4,285 Ohio
64dodge572
Ohio
Looking at the transmission, the reverse tab would be at the 10 o'clock position for neutral, 2 o'clock in reverse.
Wayne
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: toplescuda]
#2159241
09/22/16 04:47 AM
09/22/16 04:47 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
Ok. First will say. Car has no starter or wiring and no driveshaft With out any of the rods on. I can move reverse from straight up to the 10 o clock pos. I can move the lever closest to firewall from straight up to 10 o clock pos. That is 3/4 gear correct?) is so meaning I can get go into 3rd but not 4th? The other lever (1/2?) I can't get to move foward or back. All this is by hand only. I didnt pry or try force anything Do think if could rotate the tranny by putting driveshaft in and turn by hand would move insides to could go through all gears?
[Re: toplescuda]
#2159244
09/22/16 06:05 AM
09/22/16 06:05 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
The ends of the tranny I know I have like in the pic. I need see if I have them in that order mounted on the shifter When I was trying to work the levers on the trans. The shifter was not attached
