Re: INSTALLING SPRINGS ON STRUTS
[Re: Magnumguy]
#2158349
09/20/16 10:10 PM
09/20/16 10:10 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
Bill better and cheaper to get a quick strut.IIRC they need a compressor.Then usually the isolators are bad more cost.Look up quick strut ill bet around 80 bucks or less.Rock auto usually has the best price.I always replace in pairs as a car that old the spring is worn out also.Rocky
Chrysler Firepower
[Re: Magnumguy]
#2158430
09/20/16 11:28 PM
09/20/16 11:28 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I use the weight of the car to compress the spring. First thing is to break the upper nut free. then jack the car up using the LCA, put the frame on a jackstand but keep the jack under the LCA with it up as far as you can, then out the strut mount bolts, the finish taking off the upper net, slowly lower the LCA. Installation is the opposite. Worked on ever strut car I ever had to replace springs on, 86 Daytona, 05 Neon, 89 Voyager, 95 Mustang whatever year Cobalt my daughter had.
[Re: therocks]
#2158466
09/20/16 11:53 PM
09/20/16 11:53 PM
Posts: 10,646 S.E.Ohio
Magnumguy
S.E.Ohio
Bill better and cheaper to get a quick strut.IIRC they need a compressor.Then usually the isolators are bad more cost.Look up quick strut ill bet around 80 bucks or less.Rock auto usually has the best price.I always replace in pairs as a car that old the spring is worn out also.Rocky Thanks, I do plan on replacing both of them. Front one broke about a year ago, same way.
[Re: Magnumguy]
#2158656
09/21/16 11:47 AM
09/21/16 11:47 AM
therocks
Niles , Ohio
At the cost of springs and labor its not worth it most times to not get quick struts.Cost of springs,labor to remove/install,usually the plates and insulators.You have more than a complete strut.Usually just the labor savings offsets the price and its all new.Rock Auto typically has the best price on them.Rocky
Chrysler Firepower
[Re: Magnumguy]
#2158708
09/21/16 01:18 PM
09/21/16 01:18 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
At the cost of springs and labor its not worth it most times to not get quick struts.Cost of springs,labor to remove/install,usually the plates and insulators.You have more than a complete strut. This is true. I thought maybe he had a buddy that worked at a shop and he could use the spring compressor for next to nothing. That's what I did when I put drop springs on a Stratus I used to have. Just took them to my friends work and we swapped them after hours.
[Re: Magnumguy]
#2158791
09/21/16 03:13 PM
09/21/16 03:13 PM
therocks
Niles , Ohio
Even at work we started uson quick struts on most.Between less labor and not having to buy other parts say bearing plates etc that have 100K or more.The price was close to just replacing the strut and a better ride with all new.Rocky
Chrysler Firepower
[Re: Magnumguy]
#2158868
09/21/16 05:32 PM
09/21/16 05:32 PM
therocks
Niles , Ohio
Funny Ive installed many.Both at work and at the shop when I was there.They are Monroe.so if you buy any but you might get junk.Maybe you need a different supplier.Monroe uses the same strut and springs they sell seprately. Rocky
Chrysler Firepower
